12-03-2009, 05:29 PM
1995 30' Limited
Tygh Valley
, Oregon
Plastic medicine cabinet latches
Does anyone know where I can get a replacement plastic medicine cabinet latch for my 25 foot '87 Sovereign?
Take a look at the attached photos. One of the photos shows a complete, unbroken latch, the other shows the broken piece.
These latches are a hard, white, plastic that attach to the cabinet with two pop rivets. The latch is about 1" wide.
12-03-2009, 06:42 PM
San Angelo
Wow, I can't believe that they still used that crappy part in '87! Ours broke in the same spot as yours and I epoxied it, but it broke again.
When you find a source, I'll need to get one too.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
12-03-2009, 10:47 PM
Greeeneville
, Tennessee
Try Out-of-Doors Mart
They may be able to help you.
Kevin with Baity the Lab/Pointer //------AIR # 7303------\\ WBCCI 17109 visit my restoration blog at:
12-04-2009, 06:51 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
The part is made form aetel, trade name from Dupont Delrin. You can not get any epoxy or other high strength adhesive to stick to it. You might try and make an equivalent part from metal.
12-06-2009, 09:02 AM
San Angelo
Actually, the epoxy I have did stick to it, but it broke again in a different spot.
I'll just find some new ones and keep them handy.
This is the closest that OODM has: http://odmrv.com/catalog/index.php?m...roducts_id=646
Frederic
AIR # 8239
EX-WBCCI # 8371
03-24-2012, 05:49 AM
2008 25' Safari FB SE
Medina
, Ohio
My '92 latch like this just broke. Does anyone know where to get one of these or any suggestions for something else? This holds the upper bathroom mirror cabinet closed.
Liz, Brian and 3 Yorkies
The Silver Pearl & The Black Pearl
2008 25' Safari FB SE Queen converted to King
2014 Ford Expedition EXP Limited 4x4 V-8
McKesh towing mirrors
Centramatic Balancers
Hensley Swift-Arrow Hitch
05-08-2017, 08:07 AM
2005 31' Classic
Venice
I need 2 medicine cabinet latches for my 93 Classic...Called Airstream & they are no longer available...out of door mart, no. Vintage Airstream Supply no.
Any ideas ???
10-21-2020, 01:08 PM
2002 19' Bambi
1989 29' Excella
1980 28' International
Avon
Has anyone found out where to get these latches? Or maybe a possible solution? The latch on the upper mirror bathroom cabinet in my '89 Excella just snapped. The challenge with finding alternate solution is the fact that the swing out mirror/door has nothing like wood or plastic to screw anything into, it's just the mirror.
02-10-2023, 11:21 AM
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
Yep... We're looking too. Does somebody have a 3D printer that can make parts in a flexible material?
It's amazing the part has lasted this long - about 30 years. Even though it may be considered "cheap" plastic, that's not too bad. If a replacement lasts another 30 years that would be great!
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
02-11-2023, 08:38 AM
2017 25' International
West Lake Hills
I’m one of many folks here that 3D print items for the trailer. Based on the photo a replacement part should be easy to design.
POM (Delrin) filament is available but looks to be difficult to print due to poor bed adhesion. I’ve not printed with it. I wonder how a part printed in ABS or nylon would perform over time.
Anyone attempting to design it would need very accurate dimensions measured with digital calipers or the entire part. Another obstacle is in testing it without a trailer nearby. These things usually take a few design/build/test cycles to get exactly right.
07-28-2023, 09:13 AM
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
Out of Doors Mart - Suitable Substitute?
I was not able to find a replacement for the original latch. Seems odd since it was used widely in the late 80's through much of the 90's. Oh well.
I took a chance and ordered part number 005308 from Out of Doors Mart.
The part from ODM may be a reasonable substitute although not a direct fit. You can see from the pictures that I needed a wood spacer to locate the latch so it would work properly. I also had to drill new holes in the side of the medicine cabinet at the mounting feet were in a different location compared to the original. Hope it works well... Time will tell.
I didn't have the correct grip length for my rivets so I added a small hex nut as a spacer. It doesn't look so great but it's on and ready for the next trip.
Lucius and Danielle
07-28-2023, 09:25 AM
Magnetic Latch
Some years ago I had the same problem on a '90 Excella 25.
Solved with just a magnetic latch on the overhead medicine cabinet door.
Works just fine and I am pleased.
07-28-2023, 11:30 AM
1994 25' Excella
Waukesha
, Wisconsin
I've read about people have replacements made by 3D printing them. If there is a maker space in your area, this might be a good time to get involved. Or, find a friend with a 3D printer.
Richard
11018
02-18-2024, 06:00 AM
1991 29' Excella
Tulsa
, Oklahoma
Hello…
I was wondering if you would mind sharing what type of magnet you used and how you configured it? I have tried using a strong magnet but it’s not working. I sure wish I could find a direct replacement or some where to have a 3d printed.
Thanks!
