Old 02-20-2021, 05:12 PM   #1
1973 Argosy 26
North , Virginia
Pic request - Argosy or similar with a front dinette or desk
PO attempted to do a front full size bed layout on my 26' Argosy (double bed floor plan) and I want to change it to be either a desk or dinette. Most of the pics that I come across are on models where the door is further aft due to the side window. So I have come here for inspiration. I dont think I want a U shaped dinette for a couple of reasons.
  • Lack of space
  • The seat on the front wall would have to have an odd backrest in order to not protrude into the window opening
  • Seems easy to hit your head on the overhead cabinet when getting in and out of the front wall seat
Attached are the layouts I am considering, any pics or suggestions would be appreciated.
ID:	389081   Click image for larger version
seal is offline   Reply With Quote
Old 02-20-2021, 10:26 PM   #2
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
I did a banquette to have more seating and it makes into a bed.
Name:	Dinette slid forward.jpg
The extra cushion and cushions from the long end make up the bed.
An ottoman can be attached on the long side for putting your feet up or as a backless extra seat at the table.
Name:	Ottoman in place.jpg
ID:	389112   Click image for larger version
Name:	Banquette with cushions.jpg
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 02-20-2021, 11:39 PM   #3
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
Argosy 26' dinette
Attached is a picture of the dinette in our 28' Argosy. I rescued this from a 1975 26' Argosy that was being gutted and modernized, I also acquired some wall panels, used those to replace de-laminated and water damaged dinette panels and had the seat cushions remade with new foam and upholstery. I have the original above the floor water tank and the dinette is boxed out to cover that, so reduced legroom at the front wall.
It comes to the middle of the window which would be the side of the door in a 26' and the opposite side is the same length. The shorter length leaves enough wall for the fire extinguisher by the door. The black dot is a 12v outlet. I have seen an original 28' with the opposite side sofa extending all the way to the kitchen counter.
Past President, Vintage Airstream Club, WBCCI # 7291
1977 Argosy 28 Center Bath
(CA made) and 2015 Ford F250 6.7 diesel. Used to own 1978 Argosy Minuet 6.0 and 2013 Toyota Tundra
rvb is offline   Reply With Quote
Old 04-02-2021, 11:05 PM   #4
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
We took the dinning table out and cut in down and made a booth seating in our classic 25’ [ATTACH][ATTACH]
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 04-04-2021, 10:52 AM   #5
1973 Argosy 26
North , Virginia
I like, do you have a pic from a little further back?
Old 04-05-2021, 09:27 AM   #6
Julie-Bob's Avatar
2009 25' FB Classic
Here are some of while we were building the booth. [ATTACH] [ATTACH] [ATTACH]. PM me if you need more information.
ID:	392456   Click image for larger version
Old 04-05-2021, 07:31 PM   #7
Julie-Bob's Avatar
2009 25' FB Classic
Originally Posted by seal View Post
i like, do you have a pic from a little further back?
[attach]
Dinette restoration pics request Ndcctrucks Interior Restoration Forum 12 02-08-2021 10:07 AM
24 Ft Argosy :: 1974 Argosy 24T - twin beds with front dinette alfaguyair Airstream Registry Discussions 3 03-31-2012 07:44 AM
Question regarding cold/waste water tanks on Argosy's and similar vintage Airstreams. Rick F General Motorhome Topics 5 09-13-2011 06:37 PM
Looking For Pic Of U2 In Front Of An Airstream therealtoddster Off Topic Forum 0 10-26-2009 10:42 AM
