Old 08-27-2021, 01:25 PM   #1
steilkurve's Avatar
2020 22' Bambi
2022 25' Globetrotter
St-Laurent , Quebec
Lock for 22FB closet door
If you own a 22FB (Sport or Bambi versions), you may have been looking for a way to ensure the door doesnít fly open as you drive. I know I have.
I have tried putting Camco Ďbarsí to secure items inside to avoid them pushing the door open. Iíve also upgraded the latch to the 10# version. While both have worked to some extent, I still had the odd door opening on rougher roads.
I think Iíve finally found a solution that works. I added this push button lock from Lee Valley.
https://www.leevalley.com/en-gb/shop...nob-with-catch
The button itself is not plastic with a finish added. Itís actual brushed nickel and matches their hardware in my 2020 Bambi. Mechanism is plastic put looks sturdy. See the result in the video below.
https://youtu.be/z_wCsA34vDA
Quite happy with the outcome. Thought Iíd post in case helps others looking for such a solution.
Any questions, let me know.
steilkurve is offline   Reply With Quote
Changing door lock to home lock airking Windows, Doors, Locks & Vents 20 04-26-2022 07:24 AM
Interstate closet door lock? InterBlog Sprinter and B-van Forum 18 07-06-2019 05:17 AM
Thief damaged my FC cargo door lock attempting to gain entry now key wont open lock luckysgt663 Doors & Locks 14 04-01-2019 02:57 PM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 10:19 AM
closet door knobs buckmaster Cabinets, Counter Tops & Furnishings 5 11-07-2002 08:09 PM
