Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 06-02-2011, 08:29 PM   #1
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
Kitchen faucet replacement?
I've used the search feature, but have not found the info we need. While dewinterizing our Airstream, we broke the kitchen faucet. We can get a standard rv replacement faucet, but I didn't like the original to begin with. Does anyone know of a suitable replacement faucet from somewhere like Lowes or HDepot that would fit our trailer sink but be a taller unit, easier to put pots under and that has the detachable spray head? I'm not even sure what I'm describing makes "faucet" sense! Thanks for any leads. ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 06-02-2011, 08:34 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Any standard kitchen faucet should fit, the only issue is the spread (the distance between the hot and cold supply lines). Find one you like at the local big box store.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 06-02-2011, 08:35 PM   #3
Ottawa , ON
Not sure I understand your question, but I don't see why you can't pick whatever faucet you like. To my mind, RV faucets are no different than home faucets.
Old 06-02-2011, 08:43 PM   #4
KerriO's Avatar
2008 27' International CCD FB
Bay Area , California
Yup. I just happened to do a little research last night about the faucet that came in our 2008 International. It's a standard kitchen faucet. And I was surprised to learn that its retail price is $400+. That's one thing they didn't skimp on. (I just wish it pivoted. It's a pullout, but the stem doesn't move).
KerriO is offline   Reply With Quote
Old 07-07-2011, 05:48 PM   #5
ldomela's Avatar
2010 27' FB International
Portland , Oregon
Images: 59
We replaced ours with this one from Home Depot and could not be happier with it. (Well, I guess I'd be happier if it had cost less, but it's very nice.) It now pivots (without me forcing it to pivot, as I occasionally did with the old one) and has a pullout, with stream and spray and pause buttons.
p.s. If anyone has a good recommendation for a shower faucet replacement, let me know. The pause function on ours has stopped working efficiently (maybe it's just a filter thing that can be replaced?)
Riveted (blog)
Instagram
ldomela is offline   Reply With Quote
Old 07-07-2011, 08:04 PM   #6
WineStream's Avatar
2023 30' Globetrotter
Pleasanton , California
Images: 24
We completely remodeled the kitchen of our '74 Overlander last winter. We selected a single-hole pull-out faucet with switchable stream or spray. Some seem surprised that the spray function works well in an RV (low pressure), but ours works fine whether on water supply or on the pump. I've attached the best picture I have of the faucet...I never really highlighted the faucet in any of the photos. We love the compactness yet full function of it. It's great to have the spray and pull-out function. It saves a lot of water so when on boondocking / limited hookups it lessens the frequency of dumping the gray tank and filling the fresh.
Name:	P1010802 (Small).JPG
WineStream is offline   Reply With Quote
Old 07-07-2011, 08:14 PM   #7
ldomela's Avatar
Portland , Oregon
Images: 59
Looks great. Love your countertop too!!
Riveted (blog)
Instagram
Old 07-07-2011, 08:29 PM   #8
KerriO's Avatar
Idomela, I forced ours to pivot, too, because I didn't realize it wasn't supposed to at first!
We got an Oxygenics shower head based on the many glowing reviews around here. It's not the prettiest design (it's not terrible either), but the water efficiency is a big boon.
Winestream, your counters look lovely.
For those with the Elkay faucet that comes in the Newer Internationals, replacing the aerator with one that creates higher pressure (by allowing less water through) makes a big difference.
Old 07-07-2011, 08:32 PM   #9
ldomela's Avatar
Portland , Oregon
Images: 59
KerriO: haha yeah, and Kevin had to keep tightening it. What the heck though with no pivot?
Thanks for the tip on the shower head...we will check it out!
Laura
Riveted (blog)
Instagram
Old 07-07-2011, 08:46 PM   #10
smhx4's Avatar
2012 30' International
Scott AFB , Illinois
Hm. Didnt know about the no pivot thing. We're about a month away from getting our 2012 international. I love the large sink and guess I missed the faucet, I thought it was a little modern for me but that's it. I doubt I will like it now. Never had a faucet that didn't pivot.
smhx4 is offline   Reply With Quote
Old 07-07-2011, 09:29 PM   #11
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I think that Lowe's has the best design in faucets at a reasonable price.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 07-11-2011, 10:11 PM   #12
ldomela's Avatar
Portland , Oregon
Images: 59
Thanks for the Oxygenics tip. We love it. Random Stats: Showerhead - Riveted
Riveted (blog)
Instagram
Old 09-11-2018, 11:01 AM   #13
2007 28' International CCD
San Marcos , California
Georgia, I went online to Amazon and purchased a Kohler faucet that fit my Airstream perfectly. I purchased a high arch with a pull down spray so that I could more easily fill pots and rinse dishes. The Kohler spray feature stays engaged even in low water pressure systems. My original faucet never did. I wish that I could send a picture, but I have yet to figure out how to upload pictures into these threads. Best of luck, Mike.
BlueStreakSD is offline   Reply With Quote
Old 09-27-2020, 08:43 AM   #14
1998 34' Excella 1000
Indian Trail , North Carolina
I'm replacing my 1979 kitchen faucet and not replacing the stainless sink. I've bought two "standard" kitchen faucets and THEY WON'T WORK. The hole and space for the faucet is too small for a standard faucet. Does anybody know the Moen replacement faucet number that will work with a 1979 sink?
sclontz is offline   Reply With Quote
Old 09-20-2021, 06:38 AM   #15
1998 28' Excella
Shelby , North Carolina
also needing to replace faucet
We have run into the same issue on our 98 Excella. The faucet is leaking at the main base and the pull out sprayer/faucet has micro cracks so water sprays out in fine sprays when you turn it on. We also have a Moen but the ones we have looked at will not fit. We tried replacing only the spray head but then noticed the leak where it joins the plate. I hope someone has information that will help us.
Lattimore is offline   Reply With Quote
Old 12-10-2021, 11:26 AM   #16
2017 27' International
Antes Fort , Pennsylvania
On a realted note, is is easy to replace just the pulldown spray hose? Just unscrew from both ends then thread it back down and reattach? Thanks.
alphamale49 is offline   Reply With Quote
Old 04-14-2023, 07:36 PM   #17
1973 Argosy 22
Vfyuhhv , West Virginia
Did you ever find a replacement that fit?
73Argusy is offline   Reply With Quote
Old 04-15-2023, 09:06 AM   #18
I used a Koehler “Simplice” kitchen faucet. It fit perfectly and was a simple installation. It was some years ago, but I believe that I purchased it from Lowe’s. It has all the features that you describe in your post. Mike.
Where can I get a new cartridge for a Fontana Faucet? Alan3940 Sinks, Showers & Toilets 9 02-22-2017 03:38 PM
Portable Kitchen - the ideal AS Charcoal Grill tarheel1972 Full-Timing 25 08-03-2011 03:41 AM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
Replacement Gold Cone Light for '58 mello mike Lights - Interior & Exterior 7 03-17-2011 10:56 PM
Pls HELP Replacement of Deadbolt in Handle of '90 Elf1 Doors & Locks 8 01-28-2011 08:16 PM
