Old 04-08-2024, 12:08 AM   #1
1981 31' Excella II
Melbourne , VIC
Is this spray insulation thick enough?
Hi all,
Very excited to be posting after lurking for months... I am renovating the interior of a 1981 Excella in Melbourne Australia, so I will have a lot of questions.
My first one is - I have started removing the interior skin and the spray foam insulation doesn't fill the cavities. Should it? It is thicker close to the ribs and thinner in the middle which makes sense but not sure if I should pack out the thinner parts...
Also, there is discoloring around the top windows, it looks like rust but hoping someone can confirm?
Thanks in advance,
Gail
ID:	442554   Click image for larger version
ID:	442556   Click image for larger version
GailyD is offline   Reply With Quote
Old 04-08-2024, 06:03 AM   #2
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
IMHO, i would spray it so that is deeper than the ribs.
then use a std insulator installers knife to trim them so that they are level
us the two ribs and the depth indicator
finally add a vapor barrier product and use the red tape to seal the seams
be sure to run any wires and pipes in the wall first
2023 25' FB FC, hatch, Queen, 30A, 1AC, Awning pkg, Convection uwave.
Multiplus 12/3000-50, 700A Lion, MPPT 100/30, Orion-TR 30, Cerbo GX,GX touch 50, Lynx distributor, dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors
NCR , Ontario, VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Old 04-08-2024, 07:51 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the Forums!
Is that original spray foam, or something you have put in place?
Either way, I would say that the entire volume of the wall needs to be filled with whatever insulating material you use. With conventional insulating materials (foam being one of them), the thicker the insulation, the higher the R value. Not having the wall cavity completely full just doesn't make sense.
good luck!
Old 04-08-2024, 04:47 PM   #4
1981 31' Excella II
Melbourne , VIC
Thankyou! This is what I found when I started to take the skin off (not finished)., so the original insulation.
It was my feeling that it should fill the cavity so good to have that confirmed.
Sounding like i will be topping up the insulation when the time comes…. Or pulling it out and starting again.
Got a lot to do before then but helps in planning.
Old 04-08-2024, 06:10 PM   #5
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
That is not the original insulation. Airstream used pink fiberglass insulation in the walls. Somebody has added that after removing the interior. Be careful if you decide to add more spray in insulation, as if it not the same product, there could be a potential chemical reaction between the 2 different foams. There is also a possibility that the foam you have is a formaldehyde mixture, which is toxic, but was used for many years until banned.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is online now   Reply With Quote
Old 04-08-2024, 06:39 PM   #6
1981 31' Excella II
Melbourne , VIC
Thanks CBWell - I mis spoke meant not newly put in by me but yes, the last renovator put it in.
That is a great tip about adding more though, which i dont really want to do anyway but definitely not if it won’t work with the old foam.
Will take care whatever I do if it may be toxic, appreciate the heads up.
Old 04-09-2024, 09:10 AM   #7
Belegedhel's Avatar
Houston , Texas
You don't really have to add more spray foam, you could just fiberglass batting, and split it down to the right thickness to fill what space you have.
good luck!
Old 04-09-2024, 09:32 PM   #8
1981 31' Excella II
Melbourne , VIC
Thanks everyone, that is all really helpful.
At this point I am thinking I will add more insulation [batts] to fill in over the spray foam as suggested. It's a little way off so let's see what happens!
Much appreciated.
Old 04-10-2024, 07:05 AM   #9
Wabbiteer's Avatar
Jupiter , Florida
The discoloration is likely aging from ultraviolet sunlight exposure - a couple thin coats of exterior grade wall paint should arrest any further accelerated aging, just the first 16-inches around openings where trim rings etc. let day glow into the foam. Titanium Dioxide, the white pigment used in white paint, should last near forever.
The days are short and the night is long and the stars go tumbling by.. . D. Witte
Old 04-11-2024, 04:33 AM   #10
1981 31' Excella II
Melbourne , VIC
Thanks Wabbiteer, great intel .
Old 04-14-2024, 07:18 PM   #11
Poulsbo , Washington
Foam application thickness
Use care when applying new foam.
A good thick layer of foam sounds great, unless the foam is designed to go on in thin layers, allowing it to transition from a gooey liquid to a properly expanded and well insulating foam.
Applying it in one thick layer may result in an unpleasant surprise when you shave off the unwanted high spots and reveal the still-liquid sticky gooey mess beneath the surface.
Having said that, I have had good success just filling up cavities between exterior and interior steel body panels on a double-walled van. Maybe it cured correctly, maybe it didn't. But it kept the van comfortable through Las Vegas summers.
HappyNomads is offline   Reply With Quote
Old 04-14-2024, 08:02 PM   #12
2008 22' Safari
I disagree that filling it thicker is necessary or even particularly helpful. The insulating properties of that existing foam is adequate…and it is largely sound-proofing anyway. I’d leave it in situ if it were mine.
You insist on more insulation..?? add fiberglas batting. IMO.
Old 04-16-2024, 05:07 AM   #13
steinVT's Avatar
1956 22' Safari
1962 28' Ambassador
Williston , Vermont
I guess I would have to agree with Boxite. If you were to fill the cavity, it would be "better" insulated, but you might not see any difference. I performed an experiment back in 2021 when deciding what to install in my '62 Ambassador. I did not include foam in place, but the results of using various insulations demonstrated you need something, but types and amounts didn't much matter.
To see the details of my experiment, click on the "1962 Ambassador" link in my signature and go to post #133. - Mark
Our Restoration Blogs: 1956 Safari and 1962 Ambassador
steinVT is offline   Reply With Quote
Old 04-16-2024, 10:23 PM   #14
1981 31' Excella II
Melbourne , VIC
Thank you both, I love that 'do nothing' is becoming an option! I will check out your test steinVT.
Old 04-16-2024, 10:39 PM   #15
Some Guy
djarrett's Avatar
1968 26' Overlander
2021 25' Globetrotter
Nashville , Tennessee
Remember - an air gap on the inside has insulating properties of its own. So, I wouldn't go through the hassle of adding more. What I would do is to find a very thin rubber based tape to cover the ribs before adding them back to act as a thermal break to prevent the aluminum skin touching the outer portion of the rib transferring the cold or heat to the inside skin that is touching the raw rib that is carrying the thermal load from the outside to the inside. I've never understood why the factory doesn't do this.
The Jarretts
Nashville, Tennessee
1968 26' Overlander
2019 RAM PowerWagon TV-Petrol Hemi
WBCCI # 22342
djarrett is offline   Reply With Quote
Silicone spray or Graphite spray The Driver General Repair Forum 13 08-29-2022 01:58 PM
Spray Foam Insulation Question Gkiesel General Repair Forum 6 11-21-2019 05:43 AM
Spray Foam Insulation chriscrimmin General Interior Topics 246 02-23-2018 01:45 PM
Spray polyurethane foam insulation sfixx Exterior Restoration Forum 58 05-29-2011 08:45 AM
Spray insulation Annabel Exterior Restoration Forum 6 03-17-2006 09:37 PM
