I'm in the process of teardown/remodel on my
1971 Sovereign 31ft -- Airforums.com
And I currently have the stock interior removed as well as the rear most section of floor.
Part of my rebuild involves remodeling the AS to better fit our needs, and one of those things on the list is a big bed for the adults. I plan on making it a rear bedroom layout with a queen sized bed where the original rear bath was. That means I'll be moving the black tank somewhere else.
I was already thinking about leaving the space under the bed hollow with storage around the edges so I could use the original rear access hatch as a place to store larger items under the bed.
But this morning as I pulled the black tank it dawned on me.
Has anybody ever converted the space that was occupied by the stock black tank into extra deep storage?
I was thinking that when I put the new flooring back in, I'd cut a large square hole and then make a metal (steel or aluminum) drop in that was suspended by the 3/4" plywood and was about 6-7" deep (with a drain) and that would add a little more storage for things like folding chairs or an outside heat torch/lamp. Nothing heavy, just bulky.
If I don't use it, I'll just end up with a large empty cavern below the floor, because I won't be modifying the frame to remove the drop that was back there for the original black tank.
thoughts?
warnings?
have I gone too far?
