RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 06-24-2017, 06:42 PM   #1
1972 25' Tradewind
Calgary , Alberta
Interior skin removal question
The interior skins around the door are they rivited under neath the interior door frame? 72 tradewind?
Anyone have a quick answer, close to there now... I don't want to take the door out, I hope I don't have to take door out.
Monza is offline   Reply With Quote
Old 06-24-2017, 06:50 PM   #2
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Door Trim
My 72 Sovereign slid out from behind the trim when I got the rivets out of the panels around the opening. I made the mistake on my 71 and took the trim off before I realized their was no rivets
cole3444 is offline   Reply With Quote
Old 06-24-2017, 09:42 PM   #3
1979 23' Safari
Wayland , New York
The skins around the door behind the door frame trim should not be riveted. The door trim should be held in by clips that pinch it into a track around the door frame. It can be gently pryed away from the door. That is as long as nobody riveted it in through the door itself.
Old 06-25-2017, 08:13 AM   #4
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
My 74 Overlander had the door trim attached via pop rivets installed at a 45 degree angle through the inside corner of the door jam. Open the door and check inside the jam for pop rivets. Drill them out and the trim should pull away easily.
TheGreatleys is offline   Reply With Quote
Old 06-25-2017, 01:11 PM   #5
Rivet Polisher
1973 31' Sovereign
Mt Pleasant , North Carolina
Our 73 Sovereign was riveted behind the door trim. The trim was easy to pull off but be very careful not to bend it at all.
-Jim Pantas
1973 31 ft Sovereign
2009 Chevy Express 3500
wildhorses is offline   Reply With Quote
Old 06-26-2017, 08:20 AM   #6
1972 25' Tradewind
Calgary , Alberta
Thanks for all the replies. It was a bit of all of the above. The rivets under the interior frame I chiseled off from the side, left the frame in place, scarred to bend it on removal, it doesn't seem to want to budge. I'll look again when I'm not so focused on the bigger picture of getting all the skins out.
All interior skins removed. Pop the top of this thing next...
I'll start my full Monty thread soon.
Old 06-27-2017, 07:26 AM   #7
Chillpoints's Avatar
1992 29' Excella
Asheville , North Carolina
curious about how to remove the interior skin on ceiling. Is there a way to do this without removing all the cabinets? The center section is a long strip that seems to be flexible enough to remove once all the lights, AC etc are out of the way. The area where the center strip connects with the side panels does not appear to have fasteners but I can not see below. Any idea if this is possible? I am looking to install some new wiring for WeBoost and also some additional reflective foil to the ceiling if possible without doing a full Monty.
Looking forward the next thread.
Jonathan Hettrick
'92 Excella 29'
Dodge Ram 1500
AIR # 59179
TAC NC-12
Chillpoints is offline   Reply With Quote
Old 06-27-2017, 10:20 PM   #8
1972 25' Tradewind
Calgary , Alberta
Chillpoints, I don't think that would work. Not sure I'm a rookie, there may be a way. For my total removal of skins, I took the next level down first- next to the center panel. I can't recall how else it may have worked, sorry
Old 06-28-2017, 04:46 AM   #9
1992 29' Excella
Thanks for the quick response. I am hoping there is a way to run wires without taking everything out.
Jonathan Hettrick
'92 Excella 29'
Dodge Ram 1500
AIR # 59179
TAC NC-12
Old 06-28-2017, 06:33 AM   #10
lonewolf1977's Avatar
1957 26' Overlander
Winston Salem , North Carolina
My ceiling was one big piece that ran end cap to end cap and extended on the sides to the top of the windows. I called it a big upside down taco. If that's the case with yours, you will have to remove the cabinets to get to the wiring. If you have buck rivets running down the center, don't drill those out, they hold the pieces together....they don't hold the ceiling to the frame.
Airstreamin' dreamin'.
Follow our blog! https://theoverlanderproject.blogspot.com/
lonewolf1977 is offline   Reply With Quote
Interior skin removal SILVER BEE Interior Restoration Forum 5 04-15-2015 09:53 PM
Interior Skin Removal Front Roadrunner General Interior Topics 2 04-15-2014 07:12 AM
Interior skin removal. 1959 Avion Sprouty Vintage Kin 2 04-07-2013 10:47 AM
Interior Skin Paint Removal Question... sandrad Upholstery, Blinds, Walls & Interior Finishes 2 07-18-2010 09:36 AM
interior skin scrap for exterior skin patch? whatsherface Ribs, Skins & Rivets 1 06-12-2010 08:56 AM
