Old 05-01-2017, 07:02 AM   #1
1975 31' Sovereign
nashville , Tennessee
interior cap piece on airstream 1975 sovereign trailer
WE are restoring our airstream and the big plastic piece over the living room area is cracked. What can we do to replace or substitute this?
Kerrie
kerrie71 is offline   Reply With Quote
Old 05-01-2017, 07:14 AM   #2
youngpeck's Avatar
1976 25' Caravanner
Mancos , Colorado
Can you post some pictures?
youngpeck is offline   Reply With Quote
Old 05-01-2017, 07:23 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the forums.
These interior endcaps can't be purchased new, and are hard to find used in good condition. So your choices are to either figure out how to repair what you have, or to build a segmented one out of aluminum. Rumor has it that Colin Hyde is offering kits to build these. I have recently had some luck repairing ABS plastic using marine style epoxy based fiberglass, if you want to go the repair route.
good luck!
Old 05-01-2017, 07:37 AM   #4
1975 31' Sovereign
Pic of end cap
The top part above the windowClick image for larger version
Old 05-01-2017, 12:28 PM   #5
1972 31' Sovereign
Sanford , North Carolina
End cap
I've seen on You Tube videos of end caps that have been replace with V shaped aluminum sheets. Looks nice. Also one that did the same with Balsa Wood cut the same way. It look nice also. Good thing my end cap is OK.
I'm restoring a 1972 Sovereign 31 ft. Complete gut out. Right now back with lighting and wiring. Slow go when you do it by yourself and friends.
butlertyler is offline   Reply With Quote
Old 05-01-2017, 03:48 PM   #6
Unka Jack's Avatar
Fonthill , Ontario
I had to repair mine as well. Used MEK and ground up abs plastic close to the same colour as the cap is. It worked out fairly well. Then I got lazy and too the repaired parts to local the body shop to have them painted. They turned out beautifully. Both end caps, front window moldings, vista window plastic and the tub for $300. It saved me a lot of labour and time.
Although it seem like I know what I'm doing, I'm just standing on the shoulders of giants who have done this before and kindly posted their journey.
Cheers,
Jack
73's VE3ZPW
Unka Jack is offline   Reply With Quote
sovereign
Can we replace floor piece by piece? tdturn2 Repairing/Replacing Floor &/or Frame 9 07-14-2022 01:10 PM
Pickup truck cap or no cap? weber.roger Airstream Lifestyle 28 12-04-2015 06:22 AM
Where can I get a new interior front plastic nose piece? Mrcrowley General Interior Topics 4 02-03-2015 07:43 PM
End Cap and Center Piece stacyrwarren Upholstery, Blinds, Walls & Interior Finishes 3 04-07-2013 01:56 PM
Interior ABS nose piece for ceiling Mrcrowley Upholstery, Blinds, Walls & Interior Finishes 12 03-16-2010 03:27 PM
