08-24-2018, 03:18 PM
Crested Butte
Insulating Ribs?
The ribs are connected directly to exterior and interior skins. They are all metal. This is a perfect heat sync system to transfer thermal energy right around the insulation. Any ideas to mitigate this flaw? Maybe some foam tape on the ribs under the interior skin?
08-24-2018, 03:56 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Airstream put a layer of butyl tape on the outsid of the ribs to help prevent leaks at. The rivet lines. That’s probably the best you can do. It’s juts the nature of the beast.
08-24-2018, 04:08 PM
1966 22' Safari
Fredericksburg
You are thinking along the same lines as I am. Any type of thermal break on the ribs or cavity side of the exterior skins would be a plus. There have been a lot of discussions and ideas on how to achieve this. I have yet to see any results of what someone used. Mylar thermal barrier tape seems to be popular as is foam tape. I went a different route and painted the ribs and cavity side of the interior skins with Hy-Tech ceramic paint additive that they claim is a thermal break. We’ll see. The main reason I went with a paintable product in lieu of tape was so I could see the old rivet holes and re-attach the original interior skins back in the exact location. This may work, or it may not. Good luck, Bubba
08-24-2018, 04:29 PM
Central
, Mississippi
I have used 2 layers of prodex with the inner layer covering the ribs. This will not work if you try to use old panels and rivet holes. Does it help? I have no idea. Even the best insulation is offset by single pane windows. I can say that the condensation lines on the ribs are less pronounced.
08-24-2018, 06:27 PM
1974 27' Overlander
Baltimore
, Maryland
I have foam tape on my ribs. I think it's worth the price of admission if you have your interior skins off already.
08-24-2018, 09:15 PM
1986 25' Sovereign
2008 F350, 6.4L diesel
, Oak Harbor, WA
Certainly the heat flow will cause some issues for the extra hot or cold days. The ability to make improvements when a owner is reworking a trailer is a big plus. For those jobs money is less important.
From what I have seen in three trailers of different years non of which had any thermal break I concluded that AS may have put something on some of the years but not all of them.
08-25-2018, 08:38 AM
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver
I use the blue foam you put between a house's foundation and the sill plate.
https://www.google.com/url?q=http://...czoaUf4PuPQwRf
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
07-30-2020, 02:46 PM
1975 31' Sovereign
1987 30' Airstream 300
Powassan
, Ontario
Originally Posted by kidjedi
Hi Kidjedi, just wondering if the sill gasket has proven okay for you in reducing/eliminating the condensation on the ribs? I was thinking of the same thing.
07-30-2020, 06:09 PM
1972 25' Tradewind
1975 24' Argosy 24
Denver
I live in Colorado, so I don't know what "condensation" is.
However, I've placed a laser thermometer on skins at the rib area with and without the blue foam between, and it makes a HUGE difference in temperature (sometimes 50 degrees in direct Colorado sun), so I know the foam is working as a thermal barrier. If you use it, be sure to find a good way to hold it in place so it doesn't slide out of position before you get to rivet the skin to the rib (3M spray or something similar works well).
BeahmStream.com
08-02-2020, 06:20 PM
1975 31' Sovereign
Powassan
, Ontario
Thx! Good to know - big help!
08-02-2020, 06:58 PM
2018 25' International
Slidell
, Louisiana
Addition of a bit of rubber can make a big difference. Aluminum has a thermal conductivity of 237 W/mK while foams and rubbers are around 0.15-0.2 so addition of 1/16 inch of rubber is equivalent to a 40+ inch deep rib. In terms of inner wall temperature if there is say a 30 degree temperature difference the at rib wall temperature will be about 5 degrees warmer, but that understates the effect because a lot of the heat from within 6 inches of the rib is also being conducted to the rib and outside (assuming trailer inside is 30 degrees warmer than outside).
09-18-2020, 12:48 PM
1967 24' Tradewind
North Hills
Insulating Ribs
Hi, TheGreatleys, I have arrived at the rib insulation on my 24' 67' tradewind.
would you share with me the foam tape you used and if you are happy with it?
Thank you!
09-18-2020, 06:41 PM
1974 27' Overlander
Baltimore
, Maryland
Thank you!
http://www.findtape.com/shop/product...vid=440&tid=14
Worked great. I added will gasket on top of the tape for extra thickness, since I didn't really want to tape my interior skins in place.
https://thegreatleys.com/insulation
09-19-2020, 06:46 AM
1974 27' Overlander
Baltimore
, Maryland
*sill gasket
