Old 01-07-2023, 01:55 PM   #1
Ron Glow's Avatar
2018 27' Flying Cloud
Haubstadt , Indiana
How do I remove this board?
I have a 2018 27FC and I am trying to remove the divider board between the galley pantry and bathroom. I have removed all the screws I can see, but it remains held fast. I want to possibly use this "dead space" and would like to take a peak back there. I can destroy it, but would rather not.
Thanks for any ideas.
Ron
ID:	426906   Click image for larger version
Ron Glow is offline   Reply With Quote
Old 01-07-2023, 02:34 PM   #2
2019 27' Globetrotter
Missouri Valley , Iowa
Ron, you have probably looked - but are there pocket screws on the back of a panel that is connected / adjacent to the strip you are working on ?
Dan
Farmer Dan is offline   Reply With Quote
Old 01-07-2023, 03:37 PM   #3
Ron Glow's Avatar
Haubstadt , Indiana
Dan
Yes, I looked all around but didn’t see anything. Someone has surely done this before.
Thanks for responding.
Ron
Old 01-07-2023, 06:07 PM   #4
Retired.
. , At Large
I'm pretty sure that is a part of an assembly that would need to be removed to gain access to the fasteners on the back side.
Old 01-07-2023, 07:10 PM   #5
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Ron, I think you may find a vent stack in that void.
Looking for adventure in whatever comes our way.
- Brad
SuperTrouper is offline   Reply With Quote
Old 01-08-2023, 12:35 PM   #6
2014 25' FB Flying Cloud
Fitchburg , Wisconsin
I've found that Airstream often screws and dowels joints in large panels. You will probably have to do damage to get it apart. Least damage might be had using a multitool and the appropriate blade to cut the dowls.
The Airstream Parts Book for you model will show how all the panels fit together but the drawings don't always show the dowels--the joinery details are vague.
BillfromWI is offline   Reply With Quote
Old 01-08-2023, 01:44 PM   #7
Ron Glow's Avatar
Haubstadt , Indiana
Thanks Bill,
I used my endoscope from lavatory furnace duct wall hole to look back there and take a look. Could only see staples and glue holding the side opposite the 3 screws I had removed. Then I removed the slide out pantry. Still, nothing learned. Then I used the screws and screwed into the panel using the existing holes where privacy curtain was attached. This allowed me to tug on panel. Doing that, the whole pantry moved. After all of this, I think the board is integral with pantry wall and actually contributes to holding that assembly in place. I did look at the parts book and as you said it was vague.
Ron
Old 01-23-2023, 07:07 PM   #8
Ron Glow's Avatar
Haubstadt , Indiana
I decided to cut a hole inside pantry so I could get a better look. Here’s what it looks like. There is a vent stack as stated by SuperTrouper and some loose wiring. To close the hole, I made a niche to hold an electric mixer, freeing up some room in the pantry.
ID:	427482   Click image for larger version
ID:	427484   Click image for larger version
Remove White Board From Wall centennialman General Repair Forum 7 08-12-2020 08:56 AM
Replace refrigerator board with a Dinosaur board bigredandoldblue General Repair Forum 0 04-05-2020 02:54 PM
Airstream creates RV owner board to guide brand Airstream creates RV owner board. PecanMan5 Airstream Lifestyle 2 03-07-2019 07:48 PM
how to remove bulletin board w/out damage? Skooter 2005 and newer - Bambi all models 11 03-02-2014 08:18 PM
