Old 02-24-2021, 07:43 PM   #1
1976 31' Sovereign
Arlington , Texas
Hot water heater
Im thinking about putting an electric hot water heater 1 I dont have to run the gas lines all the way to the back of the Rv and also we will be at parks most of the time so we will have electricity so I wont have to run and get propane to take a shower. What is the best kind. I think I want gas for the kitchen
airking is offline   Reply With Quote
Old 02-24-2021, 08:01 PM   #2
2008 27' Safari FB SE
Miami , Florida
The recovery time for an electric water heater on 120VAC is going to be hours... Old fashioned propane will take about 30 minutes. Since you only have 6-10 gallons of hot water (depending on model) you may have quite a wait if you don’t have first “dibs” on the shower or you just finished doing the dishes.
Middle-aged (usually dirty) Nissan Titan XD
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Goofy dog
Old 02-24-2021, 08:43 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Hot water heater
Atwood 6 gallon model 90071 XT gas/electric. Just don’t hookup the gas line. Draws about 12 amps AC when heating by electricity. Recovery time is fine (~20-30 min), not much slower than LP. I use it in electric mode all the time when at campgrounds to save on LP. No problem.
wulfraat is offline   Reply With Quote
Old 02-25-2021, 04:49 AM   #4
Sag Harbor , New York
Thumbs up
. . . especially in the heat of summer, when "warm" showers are often preferable, an Atwood on electric is fine IMO.
Old 02-25-2021, 07:46 AM   #5
batman's Avatar
1964 22' Safari
modesto , California
Water Heater Options
Atwood 6 Gallon Gas / Electric Water Heater. Model #GC6AA-10E
6 Gallon Capacity
Direct Spark Ignition
Input 8,800 BTU or 1400 watt
Recovery Rate of 11.6 Gal/Hr on LP / 6.2 Gal/Hr on Electric / 17.8 Gal/Hr on Combo
It sounds like you are renovating and have to run all new lines for your propane. They are not hard to do. A tubing cutter and a flare tool, coil of copper line, line clamps some fittings, flexible rubber line to appliances. It would not be a bad idea to run the line to the "water heater" anyway. You don't have to use the propane if you don't want to. But, you might like to have the option. It will definitely add to the resale value of the trailer. My $.02
I went a different route. Precision Temp, Twin Temp JR. Heats the trailer and instant and continuous hot water (same footprint size as a 6 gal water heater) It also has an AC option but in reality needs propane to work well.
-Dennis
batman is offline   Reply With Quote
Old 02-26-2021, 03:31 PM   #6
1976 31' Sovereign
Arlington , Texas
6 Gallon Capacity
-Dennis
Thanks a lot how much are those and where can I find them
Old 02-26-2021, 04:50 PM   #7
wulfraat's Avatar
$750 bucks or so google the part number can buy them at many places
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
being frugal with hot water — best ways to manage hot water cost lbdesign Full-Timing, Winter Living & Workamping 23 12-17-2015 09:14 AM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
