Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 08-24-2016, 09:11 AM   #1
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Cheap and easy spray foam
So I ran all the numbers and order 600 board ft of tiger foam spray insulation. ($700) it should have been enough to do a whole 28 ft camper! It was not! I did about about 1/3 of the camper. Won't buy the two component again. To much inconsistency and to much to shave. Much waste!
Name:	ImageUploadedByAirstream Forums1472050808.549957.jpg
An much better way! More consistent! Less waste! Minimal to shave! 1/3 the cost! No need for respirator! Click image for larger version
Name:	ImageUploadedByAirstream Forums1472051045.776349.jpg
100 cans max ($4 x 100 = $400)
6 eznozzles ($8)
You can get cans at box stores and you get a discount for bulk buy so the above number is less! Click image for larger version
Name:	ImageUploadedByAirstream Forums1472051466.909916.jpg
Matt
rugjenkins is offline   Reply With Quote
Old 08-24-2016, 09:19 AM   #2
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Wow, is your electric inside the great stuff. Be interesting to see how much more insulated you are.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 08-24-2016, 02:20 PM   #3
rugjenkins's Avatar
1975 Argosy 28
Yep I foam everything in! Permanent now😁
Matt
Old 08-24-2016, 04:05 PM   #4
1979 23' Safari
Wayland , New York
Where did you find those eznozzles?
Did you consider using the spray foam that is deterrent to mice and pests with a buttering agent in it.
HiJoeSilver is offline   Reply With Quote
Old 08-24-2016, 11:04 PM   #5
rugjenkins's Avatar
1975 Argosy 28
Eznozzles.com
Great stuff makes a pest block. I wasn't sure what was in it and didn't want any bad off gassing.
Matt
Old 08-24-2016, 11:14 PM   #6
1995 30' Excella
Lakeway , Texas
Nice tip, thank you!
jbs411 is offline   Reply With Quote
Old 08-25-2016, 04:43 AM   #7
AWCHIEF's Avatar
2006 23' Safari SE
Biloxi , Mississippi
Images: 33
Curious how that spray foam is for moisture retention and actual insulation qualities.
MICHAEL
Old 08-25-2016, 06:20 AM   #8
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Enozzles.com shows quite a selection of nozzles. Which one did you get to fit the Great Stuff cans?
mimiandrews is offline   Reply With Quote
Old 08-25-2016, 08:54 AM   #9
Boxite's Avatar
2008 22' Safari
Spicewood (W of Austin) , Texas
Mimi,... remember those Beech Baron and Cessna 210 elevators that had foam inside them..?? and how they retained moisture and corroded the aluminum with pinholes...???
And how the ones stored indoors suffered from disintegrated foam which turned to powder from vibration...?
Hmmmnn. Perhaps fiberglass bats might be better in the long run...?
Boxite is offline   Reply With Quote
Old 08-25-2016, 10:56 AM   #10
1966 22' Safari
Sure do, I happen to own one of those 210's. I agree with you about what vibration might do to foam insulation.
However, I'm investigating foam to insulate a well house that is not likely to be subject to much vibration. Once I get my water supply protected for winter, I can get back to my Airstream and the 210.
Old 08-25-2016, 12:40 PM   #11
rugjenkins's Avatar
1975 Argosy 28
Eznozzle.com (they only sell one item)
Yep I know the whole vibration argument. Spray foam has come a long way. Closed cell spray foam- like great stuff does not hold water. In the airstream world it seals out the water, meaning it can't get in. I know there is lots of debate on spray foam. I did what I wanted on my camper... And I'm comfortable with product. It was win win for me. As for it all turning to powder in a few years from towing vibration.. We will see. There are plus an minus with everything. This one meet all my needs and requirements😄
Matt
Old 08-25-2016, 12:47 PM   #12
1966 22' Safari
Thanks, I found it. My bad. I'd mis-copied the URL you provided and ended up with a company's website that sold all sorts of fancy nozzles and not the one you had. I need to read more carefully, or learn to type, or something.
Old 08-25-2016, 05:03 PM   #13
1970 25' Tradewind
anderson , South carolina
Think about the competitor Avion foam insulation in their RV. I have a 1966 Avion c-10 truck camper (50 years old) that has been west coast to east coast and who knows where else with original foam
In place and good condition. Did one repair job inside side wall and requiring insulation removal and had to carve it out. They did not use the entire space (wall thickness) but left appx one inch air space.
You may want to consider duplication to their system. Best wishes Bob C.
Bob Cooke is offline   Reply With Quote
Old 08-25-2016, 05:08 PM   #14
"Silver Shrek"
drairstream's Avatar
2000 27' Safari
Crestwood , Kentucky
closed cell foam solidifies and will shake loose from the frame and panels. you may very well get a large amount of condensation that will run down the walls and rot your floor. I would monitor it very closely.
Just went through all these issues in depth regarding a building.
drairstream is offline   Reply With Quote
Old 08-25-2016, 09:59 PM   #15
rugjenkins's Avatar
1975 Argosy 28
If you clean the skins with acetone, one should not have an issue. I did that and also painted with an aluminum primer with a hitech additive- no issues, great bonding. I also sealed and ran a bead of caulk on all the seams and ribs. I so re-engineered the frame/shell/floor connection. My frame and shell bolt together and the floor is independent. I can remove my floor at anytime without removing the shell. The spray foam in my rebuild for me is the best option for insulation. For other maybe not. I did weigh all the options and this the one I chose. I went with rigid foam board under the floor for insulation. This spray foam technique is an option for those who maybe considering spray foam- mostly those with more time than money😁
Matt
Spray Foam Insulation Question Gkiesel General Repair Forum 6 11-21-2019 05:43 AM
Has anyone ever removed ALL of interior and inner skin to spray foam inuslation? crazeevw Classic Motorhomes 16 11-09-2014 06:47 PM
Spray polyurethane foam insulation sfixx Exterior Restoration Forum 58 05-29-2011 08:45 AM
Update, leaks and spray in foam ugggh!! Bex All Argosy Trailers 13 07-25-2010 07:45 PM
