Old 03-31-2017, 10:42 AM   #1
turk123's Avatar
2019 30' Classic
Sunnyvale , California
Adjustable Bed / Solutions
My wife and I bought a Tempurpedic bed a few years ago and we also bought an adjustable motorized frame. Most importantly, we have a king bed but it is made up of two XL twins to allow for both sides to be adjusted separately.
When we bought our Airstream, we bought the 27FB Twin. I had the idea of making them adjustable down the road. Well, down the road is here.
I started out by trying to design a wood type platform for the head of the bed. I did not care for raising the feet (we seldom do this at home), so it seemed like a simple design. I also did not need it motorized. After looking on the internet to see what others have come up with, I ran across a product that looked perfect for the job! On top of that, it was very affordable and my design probably would not improve on this.
Here is the link to the product on Amazon:
https://www.amazon.com/Drive-Medical...978456&sr=1-11
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 03-31-2017, 10:50 AM   #2
turk123's Avatar
2019 30' Classic
Installing the back support was very easy. Since the mattresses are going to be lifted at the head of the bed, I needed to support the mattress from sliding off at the bottom. The plywood deck that supports the mattress is 1/4" and screws can protrude into the outside storage area ceilings. Adding a small 1/4' rectangle of wood strengthens the deck and will support short screws. I glued the small pieces of wood to the deck.
ID:	282468   Click image for larger version
Tom & Doty
Old 03-31-2017, 10:55 AM   #3
turk123's Avatar
2019 30' Classic
Sorry pictures are rotated.
I used 1" electrical pipe metal brackets although 3/4" might be better. Be careful to measure correctly and move the adjustable brace as far to the head wall as possible without touching.
I used 4" 90 degree stainless steel braces for attaching the Matress foot support. See pictures.
ID:	282470   Click image for larger version
Tom & Doty
Old 03-31-2017, 11:02 AM   #4
turk123's Avatar
2019 30' Classic
The adjustable twin beds are wonderful! It creates a very nice position to watch the bedroom TV and as they say on TV, "It will stop you from snoring". Well I don't know about that!
One careful note: To change the angle you just pull up on the bracket from the side. Here is the rub. Don't put it down this way. It puts your hand in a precarious area for getting pinched. I am adding a thick white rope to the side of the bracket so you can pull on it to lift the arm to lay it back.
Thats it!
ID:	282472   Click image for larger version
Tom & Doty
Old 03-31-2017, 11:10 AM   #5
turk123's Avatar
2019 30' Classic
By the way, on an adjustable bed, you use stretchable cords with alligator type clips that secure the sheets on the back of the bed. That stops the sheet from ballooning in the middle when in the up position, and from pull out from behind the mattress.
We use these anyway to avoid having to buy the AS curved sheets to fit our mattresses.
Tom & Doty
Old 04-02-2017, 06:34 AM   #6
2020 30' Classic
2015 25' Flying Cloud
Blue Ridge , Georgia
Great idea and looks like a simple solution to elevating the head of the bed. Wonder if this could also be used in the dinette for elevated back rest? Thanks for the post.
Gleverett is offline   Reply With Quote
Old 04-02-2017, 03:42 PM   #7
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
We have the same motorized bed at home and I have been wondering the same thing. Looking at your setup, though it seems to raise the head of the bed too high for sleeping, but OK for TV etc. Do you take it out for sleeping to create a less severe angle?
Ray B.
Adventure.AS is offline   Reply With Quote
Old 04-02-2017, 03:50 PM   #8
Here is a link to another product that might work more like the motorized bed. It is an inflatable wedge that can inflate with the push of a button.
https://www.amazon.ca/Contour-Produc...%2Bpillow&th=1
Ray B.
Old 04-03-2017, 01:17 AM   #9
turk123's Avatar
2019 30' Classic
It's lowest position is flat. The first rung is not as high as you think. Mainly because the mattress thickness limits the angle.
Tom & Doty
Old 04-03-2017, 01:19 AM   #10
turk123's Avatar
2019 30' Classic
I looked at that one. Read the reviews. They are not happy with it. It leaks!
Tom & Doty
Old 04-10-2017, 03:36 AM   #11
2017 23' Flying Cloud
2016 Interstate Lounge Ext
New England , Ontario
Great, Great, Great idea!!!!!!!!!!!!!!! It should definitely work.
EdwardCharet is offline   Reply With Quote
Adjustable bed mkeith54 Modifications 0 08-01-2013 04:22 PM
Stove with adjustable burners tsunami Stoves, Ovens & Microwaves 1 11-25-2006 06:17 PM
Are the storage compartment doors adjustable? Becky B. Exterior Storage Compartments & Access Doors 1 08-24-2006 03:43 PM
is there an adjustable height coffee/dining table wheel interested General Interior Topics 5 10-01-2004 08:46 AM
Airstream twin Bed solutions briandeacon General Interior Topics 5 01-22-2004 10:31 AM
