Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 08-04-2020, 11:06 PM   #1
Corona , CA
Question Adding a Towel rack to wall
Hi there I want to know if anyone has advice on how attach a towel rack to the wall behind the toilet. Right now there is a wall that has wallpaper on it but not sure what is behind it and can I secure a regular mounting?
Uke player is offline   Reply With Quote
Old 08-04-2020, 11:28 PM   #2
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Hi Uke, can you tell us model and year of your airstream? That might help us help you. - Brad
SuperTrouper is offline   Reply With Quote
Old 08-05-2020, 10:50 AM   #3
Corona , CA
towel rack
Yes it's a 2006 Bambi 19ft. Thanks for any help!
Old 08-05-2020, 03:43 PM   #4
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
I'm not familiar with your Bambi's layout but I added a towel rack to the wall in front of the toilet in our Globetrotter. I ordered one from Airstream through my dealer. Probably not the cheapest way to go but I wanted to make sure it was an exact match for the existing one behind the toilet.
The new rack came with a paper mounting template and using it I eyeballed and measured everything thoroughly to make sure I wouldn't be drilling into anything or coming out the other side of the wall. I drilled holes in the wall and used the smallest plastic wall anchors that would work. The result was a bar that is very sturdily mounted and, to me, looks like it came from the factory.
Mike
2020 25' Globetrotter Twin | 2017 F250 4x4 6.7 max tow Platinum
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
mikeinca is offline   Reply With Quote
Old 08-05-2020, 05:36 PM   #5
Corona , CA
Thank you. Your's looks great. And it's in a good spot for it. Thank you for your info.
Old 08-06-2020, 10:50 AM   #6
Has anyone attached towel rack or shelf two walls of an 84 sovereign? if so, how did you do it? Thank you!
syoung713 is offline   Reply With Quote
Old 08-06-2020, 11:27 AM   #7
Something Shiny
2017 27' International
Mosinee , Wisconsin
If you are attaching the towels bar to a smooth surface, e.g., an aluminum interior wall, you ought check out Hasko. We have had excellent experience with their products inside our coach. No damage to the walls and they never come loose.
We've many friends, that when they've seen them in our coach, have done the same. They all rave about how well they work.
http://hasko-acs.com/products-catalog/
Mark & Gina
2017 International Serenity
160W Solar roof mount + 160W Zamp portable
ProPride hitch, 1400#
2018 Ford F250 Platinum 6.7L Diesel
Pongo is offline   Reply With Quote
Old 08-06-2020, 12:51 PM   #8
Toaster Life
2010 23' International
Tucson , Arizona
We added stick on hooks and they work well for towels.
Toasterlife is offline   Reply With Quote
Old 08-06-2020, 01:05 PM   #9
Mollysdad's Avatar
Not a towel rack, but I installed a grab bar on a wall with no access behind it. I used brass threaded inserts. Measured very carefully.
Very strong.
Old 08-06-2020, 04:47 PM   #10
2018 26' Flying Cloud
WARNER ROBINS , GA
Hi Mollysdad, Still loving your 26? I know we are. Got all the bugs worked out and the extras installed.
later, JRW
jrwayne is offline   Reply With Quote
Old 08-07-2020, 03:52 PM   #11
Miss Montana's Avatar
2020 26' Flying Cloud
Belgrade , Montana
Very strong.
Mollydad,
My wife and I met you at the 2017 Alumalina in Palmetto Cove RV Park in South Carolina. You graciously showed us your 26U which we loved. We towed our new 26 RBT back to Montana from Colonial Airstream last week and are loving it!
Nice job on the grab bar. Below the TV is a great location. Where did you find the hardware?
Bill
Miss Montana is offline   Reply With Quote
Experience with Rhino Rack track mounted rack? wecoyote Tow Vehicles 2 11-12-2015 03:25 PM
Bathroom Towel Rack - Relocating Frank&Mike 2006 - 2010 International 6 03-06-2013 09:34 AM
Adding towel racks and spice rack twestover Cabinets, Counter Tops & Furnishings 18 12-10-2009 11:26 AM
Towel rack inside shower? altamont Sinks, Showers & Toilets 1 02-27-2007 06:19 PM
