Old 02-08-2017, 04:24 PM   #1
1999 25' Safari
Houston , Texas
99 Safari Bathroom Sliding Door Missing
I purchased my first Airstream and it did not come with the mid bathroom sliding door. The track and rollers are still present along with screws hanging down from the rollers when the door was removed.
Was there an inherent design flaw with this type door? I notice the wall that the door covers when open is as flimsy as it gets, and I can't figure out how the door would have been latched for transit or for use.
I was contemplating replacing the wall and door with Aluminum, but still looking at alternatives. Anybody with a slider wish they had something else?
subsea is offline   Reply With Quote
Old 02-08-2017, 06:08 PM   #2
Cruiser6483's Avatar
1954 25' Cruiser
Bern - Thun , Berner Oberland
Images: 31
Why not a curtain?
Cruiser6483 is offline   Reply With Quote
Old 02-08-2017, 06:21 PM   #3
1999 25' Safari
Houston , Texas
Definitely possible, but we would prefer a door, sliding or hinged. Truth be told, I am interesting in getting into a mild project to "make it ours" and this might be the perfect opportunity to have a weekend project.
Old 02-08-2017, 07:19 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
My 2001 had the same door, I think. The bathroom was all on the road side. The door was nothing but a rectangular piece of plywood or OSB or something with a wood grain vinyl on it. Mine was secured in the open position by a clear plastic strap with a snap that clicked on its mate inside the bathroom wall. It should be easy to duplicate.
I had a problem with the wall adjacent to the door pulling away from the wall that went beside the fridge. I ended up gluing it with Gorilla Glue and it never moved again.
Al
Old 02-08-2017, 08:09 PM   #5
1999 25' Safari
Houston , Texas
I have a small problem with the wall pulling away from the aft side. Same street side set up that you probably had. I don't think I would be happy with just hanging the same quality door up. Going though the thought process now on building a new wall and door from aluminum.
Old 02-09-2017, 11:20 AM   #6
2012 23' FB International
Woodstock , Ontario
What Al said! been that way since my '89 and same in my '96
JCW
JCWDCW is offline   Reply With Quote
Old 02-09-2017, 12:21 PM   #7
JRF0st3r's Avatar
1967 22' Safari
West Fork , Arkansas
My solution included rebuilding the wall between bath and dinette so the sliding door is not in a pocket between two flimsy walls but on one side of a sturdy wall. Birch plywood is the finish for all the new woodwork and casework. Interior is complete now.
ID:	279475   Click image for larger version
Name:	2016-04-16 08.26.58.jpg
ID:	279477   Click image for larger version
Name:	2016-07-19 dinette-gaucho b.jpg
If it were easy, the PO would have done it.
JRF0st3r is offline   Reply With Quote
Old 02-09-2017, 03:44 PM   #8
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Very nice, where did you get the hardware for slides?
Cochese is offline   Reply With Quote
Old 02-10-2017, 05:34 AM   #9
1999 25' Safari
Houston , Texas
Nice work Jim.
Old 02-10-2017, 06:02 AM   #10
Cochita
1997 25' Safari
Medina , Texas
Nicely done!
Cochita is offline   Reply With Quote
Old 02-10-2017, 07:00 AM   #11
1973 23' Safari
1970 27' Overlander
Boerne , Texas
Nice work. Would also like to hear where you obtained your sliding door hardware. Also, where did you get the aluminum trim?
Greg
Greg1410 is offline   Reply With Quote
Old 02-10-2017, 10:21 AM   #12
JRF0st3r's Avatar
1967 22' Safari
Thanks for the "atta boy"'s I ordered the sliding door hardware online from Woodward's Hardware. 3/4" aluminum channel came from Lowe's. I installed a slide bolt on the dinette bench to secure the door in the open position while towing.
Sliding screen door for the sliding door! weirdstuff Sprinter and B-van Forum 29 02-28-2014 08:19 PM
1978 rear bathroom sliding door??? charlie tuna Cabinets, Counter Tops & Furnishings 4 08-31-2006 08:52 PM
Sliding Bathroom Door "clips"? Curtis-79MH Classic Motorhomes 1 06-26-2006 10:05 AM
Sliding bathroom door hardware steelbird312 1987 - 1989 Excella 2 12-13-2004 01:13 PM
