Old 05-30-2019, 12:21 PM   #1
1973 29' Ambassador
Green Valley , Arizona
Exclamation 73 Airstream 29' Land Yacht - Routing Coax Cable
Sure hope someone can help me. We are updating a 1973 29' Land Yacht and I am trying to find a way to fish the coax from the new center of roof antenna down to the box next to the refrigerator. I can't find any opening through the front to back roof beam. I'm hoping there is someone out there who has done this and can give advice. I'm stymied. Thanks in advance for any suggestions.
LouK is offline   Reply With Quote
Old 05-30-2019, 01:02 PM   #2
2007 22' International CCD
Consider going across the roof externally then down the fridge vent if there is one on the roof. Otherwise it’s take down a ceiling panel and drill holes as needed. Use bushings or flex conduit to protect the cable where it goes through ribs and longerons.
Old 05-30-2019, 02:46 PM   #3
1972 25' Tradewind
McHenry County , Illinois
You mentioned you could not find an opening in the fore and aft roof rib. If you have already removed or loosened the center interior panel (a real PIA) then you're halfway there. If you have an A/C unit the center panel may be cut in two pieces under the shroud.
While I was rehabbing the Tradewind I ran new coax to the front and rear boxes. I found the old twin lead. I was able to use that to fish the coax to the front box after drilling a hole in the rib and installing a nylon grommet. The rear was much harder due to the bedroom window and a horizontal rib.
Good Luck,
Tom
Tom Nugler is offline   Reply With Quote
Newbie question about routing coax cable theflash44 Electrical - Systems, Generators, Batteries & Solar 11 10-09-2015 11:03 PM
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
Outside Coax Cable Box & Antenna Rolo Audio, Video & TV 0 06-07-2011 07:20 AM
Cable TV/ Satellite Receiver Dual Coax Face Plate pwesterman 2008 Safari SE 2 11-14-2010 01:09 PM
2010 Int'l: Does cable coax go straight thru? or thru amp? amm3824 Audio, Video & TV 2 10-18-2010 08:32 PM
