Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 12-18-2007, 03:08 PM   #1
1968 26' Overlander
Ann Arbor , Michigan
Images: 11
68 Overlander Restoration/Mod
Hey All. I am about knee deep in my restoration/modification project.
Today, I have taken off the streetside interior panel.
I dont understand what I see.
First...I thought that when I saw the main ribs of the inside that the full end would be sitting in the c chanel...it is not. It looks to be cut to a 45 degree angle and the only side that is in the chanel so to speak is the on facing the exterior skin.
Second...I removed the furnace and it looks like one of the ribs were cut to install the furnace.
It also looks like the cross bars do not connect to the main ribs.
The windows dont seem to be attatched to the main ribs either...I could not tell because I did not go that far up the wall.
The C Chanel does not connect
The "insulation" is taped in place
What gives?
With all this said...where does the structure come from.
It seems solid, but when I took the panel off...I can wiggle the main ribs a bit.
Is this normal?
Name:	Airstream inards 2 038.jpg
ID:	51123   Click image for larger version
Name:	Airstream inards 2 029.jpg
Name:	Airstream inards 2 028.jpg
ID:	51126   Click image for larger version
Name:	Airstream inards 2 026.jpg
Name:	Airstream inards 2 025.jpg
ID:	51128   Click image for larger version
Name:	Airstream inards 2 024.jpg
Name:	Airstream inards 2 027.jpg
Aluminati is offline   Reply With Quote
Old 12-18-2007, 03:37 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Yep, thats how they are made. Mine frame to "C" channel WAS that way at first, they are tied together now. I,m still working on the stringer to frame attachments
Old 12-18-2007, 03:43 PM   #3
1968 26' Overlander
Images: 11
So where does the strength come form? Is the All Clad aluminum structural aluminum?
Old 12-18-2007, 03:44 PM   #4
1968 26' Overlander
Images: 11
Is that the original aluminum beam you have anchored?
Old 12-18-2007, 03:45 PM   #5
Retired.
. , At Large
Basically, all the parts work together as a unit that is strong, but will flex with movement and expansion and contraction from heat and cold. If you make it too stiff, you will do more harm than good.
Old 12-18-2007, 03:50 PM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by Aluminati
So where does the strength come form? ...
Terry made a good post.
If you want more detail, Google keywords "unibody", "monocoque", and "semi-monocoque". An Airstream utilizes "semi-monocoque" construction.
Tom
Old 12-18-2007, 04:11 PM   #7
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
The strength comes from the skins. The ribs are only there to hold the two skins in relation to each other. You do not want to create a point load at the ribs because that will transfer a point load to the skin. The system relies on the loads being spread over a large area. Point loads will cause rivet pops and tearing of the skins.
Just focus on repairing what is broken. The system has been proven by a half century trailers. Damage is normally caused by inadequate maintenance... as Inland Andy has pointed out many times.
Happy to see you are into the "fun" part!
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
https://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 12-18-2007, 04:53 PM   #8
Aerowood's Avatar
Arvada , Colorado
Yes that is the original frame that is now tied to the "C" channel. The channel was attached with pop rivets on the flanges of the frame but all the original rivets had failed some time in the past. Attaching the stringers to the frames will not cause the shell to become any stiffer or cause any point loads. There are more point loads now in the structure at the first and last rivet in each stringer then there will be with the stringers attached to the frame. The shell and frame work will still have the ability to flex plus giving the AS a more true semi-monocoque structure. The Airstream construction as from the factory is more of a reinforced shell then a true semi-monocoque structure.
Old 12-18-2007, 06:29 PM   #9
1968 26' Overlander
Images: 11
Stringers Point Loads O.K...please slow down...This is all new terminology for me. What by gum is a stringer and a point load. Looking at it from the outside...it looks like the window is riveted to the rib...at least I thought...is this correct. I searched for simi-monocoque but did not find anything...I will search again. Sorry for sounding like a dimwit but I am only familiar with beams, crossmembers. I have built a few residential walls, so it just threw me off when I pull the panel back and saw what I saw.
Old 12-18-2007, 06:33 PM   #10
1968 26' Overlander
Images: 11
...and I cant believe that they "taped" the isulation in place...
So if ai am understanding you correctly...the outter skin is where alot of the strength comes from. If that is true then wow...my hat's off to the guys who built this thing and that it has lasted so long.
Old 12-18-2007, 06:36 PM   #11
1968 26' Overlander
Images: 11
Your floor looks great...what did you treat it with?
Old 12-18-2007, 06:39 PM   #12
1968 26' Overlander
Images: 11
Tom
Sorry...My brain popped a bad rivet...you said Google the keywords. Me getting is bass ackwards just searched thoes words at this site.
Old 12-18-2007, 06:42 PM   #13
1968 26' Overlander
Images: 11
Missing Rivet
Can water come through a hole where a rivet used to be...on the side of the trailer. I remember seeing some water track marks from a location on the side of the trailer. There is a rivet missing.
Old 12-18-2007, 06:42 PM   #14
Retired.
. , At Large
Stringers are analogous to crossmembers, they extend out to the bow (another term) and support them through the floor. Bows are the vertical crossmembers that start at the floor, and go up to the center. And yes, the insulation is taped in place, otherwise it would fall down the inverted curve to the ceiling.
Old 12-18-2007, 06:57 PM   #15
1968 26' Overlander
Images: 11
So the ribs that I am seeing are what is called formers ( forming the basic shape of the AS)...in Semimonocoque terms? and the crossmembers that are horizontal are stringers?
Old 12-18-2007, 06:58 PM   #16
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Shameless plug.
We talked about Airstream construction a long time ago on theVAP.
-Tim
theVAP - Airstream Podcast
Old 12-18-2007, 06:59 PM   #17
Retired.
. , At Large
Yes.
Old 12-18-2007, 07:50 PM   #18
Aerowood's Avatar
Arvada , Colorado
I had several partial cans of poly that I mixed all together. semi gloss ,satin, gloss, indoor, outdoor. some tinted maple, you name it , it all went into a large can and I squeegeed it on,three coats worth. After everything is done I will most likely put some epoxy down that I have.
Old 12-18-2007, 07:53 PM   #19
Aerowood's Avatar
Arvada , Colorado
Yes
Old 12-18-2007, 08:46 PM   #20
1967 28' Ambassador
1970 29' Ambassador
True... but bearing the rib on the "C" channel/floor will. There is a reason they stop the ribs above the floor.
Steve & the crew
New Restoration Project, '72 Overlander surferstyler 1970 - 1973 Overlander 160 08-29-2013 06:28 PM
1958 Overlander Restoration Ken J 1954 - 1959 Overlander 150 06-21-2013 11:23 AM
DIY Network Overlander Restoration Series lubbockgolf Airstream "In the News" 18 06-15-2012 06:06 PM
The start of '73 Overlander restoration Lothlorian Repairing/Replacing Floor &/or Frame 134 10-24-2011 08:23 PM
1972 Overlander Shell-off Restoration Derek D Repairing/Replacing Floor &/or Frame 11 10-19-2006 07:51 AM
