Old 12-01-2023, 07:27 PM   #1
Thiss's Avatar
1971 27' Overlander
2023 28' Flying Cloud
Monmouth , Oregon
Need 110 Standard 15amp from a Pedestal Without
Want a 110 connections from the 50amp on the pedestal.
Our permanent winter spot only had 30amp (used by our Airstream) and there is an empty 50amp both on the pedestal.
Is there a converter I can buy? I want to be able to plug in my truck and Christmas lights
Will the pictured item work without burning anything up?
Thiss is offline   Reply With Quote
Old 12-01-2023, 07:59 PM   #2
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
It might work, I would call it a "use at your own risk" type of thing. It is not listed by UL or any other agency, no GFCI protection and the entire description is obviously written by someone not familiar with the English language or US electrical standards, there is no "220" in the US.
Then on the other hand it gets a lot of good reviews and just a few bad ones. The reviewer who said it sparks when you plug in a load doesn't understand that when you plug in a load that is switched on there will always be a spark.
I would feel safer making my own device and while this one may be perfectly fine I would hesitate to trust it myself. Probably the biggest issue is no GFCI protection, a big no no on an outdoor 120 volt receptacle and could put the user in danger under the right circumstances.
When you say you want to plug your truck in if you mean a block heater I would probably not trust it at all for that, poorly made connections have burned down more than a few vehicles that were left plugged in overnight, not to mention the lack of GFC protection. There outlet itself doesn't have any sort of weather protection either.
Brian
ITSNO60 is online now   Reply With Quote
Old 12-01-2023, 08:50 PM   #3
Thiss's Avatar
1971 27' Overlander
Monmouth , Oregon
For sure.
This one has a breaker
https://www.homedepot.com/p/AC-WORKS...E&gclsrc=aw.ds
Old 12-02-2023, 10:20 AM   #4
2023 28' International
Mercer County , New Jersey
You may also overload the circuit. Frequently, these pedestals that have a 50A, 30A, and/or 20A circuit are only wired for the max (50A) from the source so they only will support 50A of load, not the cumulative load of 100A (or 80A)
jeffb831 is offline   Reply With Quote
On-the-go water softener double standard swap for standard size at no cost - Texas wonderlust87 Commercial Listings 0 02-20-2022 10:23 PM
110V /15Amp/Furnace? time2travel Our Community 7 09-01-2019 06:39 AM
Standard or Non-Standard Roof Vent and Skylight man7sell Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 08-24-2018 03:38 PM
Can I Plug my 30 amp airstream into a 40amp cricut with a 30 to 15amp dogbone? StreamingB Electrical - Systems, Generators, Batteries & Solar 2 07-01-2018 08:12 PM
Replace 15amp GFCI breaker with 20amp? KYAirstream Electrical - Systems, Generators, Batteries & Solar 6 11-23-2012 09:20 AM
