OK. DO NOT put antifreeze in your fresh water tank and run the pump!! There is absolutely no reason to have antifreeze in that tank. NONE!! That creates an unnecessary mess because in the Spring you have to fill and drain it numerous times. And it complicates sanitizing the tank with bleach.
If you don’t have a way to pump antifreeze (typically a valve before the water pump that you can attach a hose to and put it down a gallon of antifreeze. Then turn on the pump and siphon it through the system) through the system you
can get a hand pump and pump it through the outside water inlet. Just takes 2 people; one inside opening the faucets and one outside pumping the antifreeze. I have done that before. Bit messier, but it works, and then you don’t have that nasty antifreeze in your freshwater tank. I REPEAT: TOTALLY UNNECESSARY TO PUT ANTIFREEZE IN FRESH WATER TANK!!
Also make sure to have the bypass valve to the water heater “closed.” Don’t want antifreeze in your hot water tank.
If you don’t have a valve to pump antifreeze from the other side of your pump I highly recommend getting one installed. Makes the process much easier.
ALSO: Make sure you have an open line before you turn on the pump and pump air through the system. And don’t forget the outside shower faucet
And if you blow out the system remember there will still be residual water in the water pump. So you have to unscrew the outlet from the pump and drain it. Otherwise your pump will be ruined.
This really isn’t complicated. Follow the instructions in the manual. You’ll be a pro at it after a few seasons.
