Go Back   Airstream Forums > Airstream Community Forums > Full-Timing, Winter Living & Workamping
Old 01-10-2010, 09:34 PM   #1
vancouverG's Avatar
1975 31' Sovereign
fairbanks , Alaska
Electric heaters
i'm living in my airstream in vancouver, WA this winter.
my furnace works fine, but i'd like to get a small electric heater to help out(1500watt or so)
they always say not to use those types of heaters on an extension cord, so i guess i'm just wondering if there are any issues using one in a 35 year old trailer with 35 year old wires.
anyone have any input??
thanks, G
vancouverG is offline   Reply With Quote
Old 01-10-2010, 09:42 PM   #2
"Cloudsplitter"
Have used this model for over 10 years, works very well.World Marketing of America B-6A1 1500W Original Disc Heater
Old 01-10-2010, 09:44 PM   #3
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
I have used ceramic heaters and oil filled in my 79 unit with no problems.
They sure help on cutting the propane usage.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 01-10-2010, 10:23 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Oil Filled.
Name:	img_0242 (large).jpg
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 01-10-2010, 11:26 PM   #5
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
The extension cord bit may be about if there is a motor (fan) in your heater, the voltage at the end of your cord might become too low for the fan motor. Most motors like full voltage and 60 cycle.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 01-11-2010, 04:06 AM   #6
richinny's Avatar
2011 34' Classic
the cord must be rated for the heater's power consumption. the longer the cord, the heavier wire you will need. you also need to check the trailer power cord ends.
we still need an opinion on the old wiring possible deterioration. anyone?
Ricky
Old 01-11-2010, 08:07 AM   #7
We use a Pelonis, electric ceramic with fan, from Camping World. Keeps propane use to a minimum.
rtaylor537 is offline   Reply With Quote
Old 01-11-2010, 11:30 AM   #8
The Polishing Guru
zinbar's Avatar
Riverside , California
Just make sure the Amps aren't too much on the heater also. they may be small but they can pull a lot of electricity. Stay Warm!
Riverside, CA
zinbar is offline   Reply With Quote
Old 01-11-2010, 12:41 PM   #9
DFK
DFK's Avatar
35 years from 2010 means your Airstream is a 1965 model or there abouts. I have a 1967 Caravel and have had no trouble with the wiring. That being said, things I would check are the amperage of the circuit breaker protecting the branch circuit of the outlet you will be using and what other electrical devices are or could be on that same circuit. I would also check the type of wiring. If it is aluminum like the wiring in my 67, then there is a possibility of corrosion occuring at the terminals where the wire is connects to the wall plug. Corrosion can result in an increase in the resistance between the wire and the terminal which, if severe enough can lead to the wire overheating where it connects to the outlet. In wood frame homes the overheating problem has lead to house fires. I would inspect the terminal connections to check for corrosion. The corrosion issue is less of a problem if the circuit operates significantly below it rated capacity. However, a 1500 watt load on a 120 v circuit can draw around 12 amps, which would be a significant amount of the capacity of a 15 amp circuit but less so of 20 amp circuit.
DFK is offline   Reply With Quote
Old 01-11-2010, 01:17 PM   #10
DFK
DFK's Avatar
Oops. My math skills clearly need some work. 35 years from 2010 is 75 not 65. I think by 1975 Airstream was no longer using aluminum wiring so the aluminum wiring issues would not apply.
Old 01-11-2010, 04:48 PM   #11
1980 31' Excella II
Drummond Island , Michigan
We use a 1500w ceramic in our '80 Excella without problems. Aluminum wiring even if your trailer has it is really not an issue if it was installed correctly in the first place. If you have been using a microwave, toaster or hair dryer in your rig you should not have a problem because a small electic heater draws about the same amount of current. If you need an extension cord please read the label and get a 12 Gauge cord, the one's that say "for appliance use" generally are the heavy guage.
Ahzmyrah is offline   Reply With Quote
Old 01-11-2010, 07:51 PM   #12
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Extension cord usage is still good advice, if you have cut some of the new extension cords you will find minimum wire is used and they have eliminated the ul seal on a lot of them. Buy a heater with high and low power setting, usually they are 750 and 1500 watts, most wiring can handle the 750 watts as long as water heater, all the lights, refrigerator, microwave, tv's and especially A/C strip heater isn't on at the same time. Good idea to have a voltage meter plugged in to watch system.
Old 01-11-2010, 09:07 PM   #13
1972 25' Tradewind
McHenry County , Illinois
I’ve been running two this winter during an interior remodel. One is a ceramic disc and the other is a cheepie wire-wound from Menards. I can manage 60f. when it’s 15f. outside. One is on a short room air extension cord.
I have 30 amp at home and don’t have any voltage drop issues until the 500 watt work lights need to be turned on. The ’72 has copper wiring and the cords and outlets are cool to the touch. (I burned an outlet up on my ’67 with AL wiring.)
So far, so good. I think you'll be OK too.
Tom.
Tom Nugler is offline   Reply With Quote
Old 01-12-2010, 11:36 AM   #14
vancouverG's Avatar
1975 31' Sovereign
fairbanks , Alaska
thank you thank you
thanks so much for all the replies..
Old 02-03-2010, 03:25 PM   #15
1972 Travelux Princess 25
Cobourg , Ontario
Are you thinking of the extension cord connecting your trailer to power? They are much heavier than a typical extension cord and present no problem.
They are concerned about connecting a 1500W heater to a dollar store cord which is way too small. Such a cord could heat up. If some papers or a a blanket fell on the hot cord it could eventually start a fire.
In your case you should not need a cord of any kind inside the trailer and the one outside is plenty heavy duty.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 02-03-2010, 06:25 PM   #16
Unless it is really cold, we run our Pelonious electric heater at half speed, 750 watts. We aren't worried about the wiring in our 2004 Safari but the heater at 1500 watts is quite hot to the touch. If the temps are in the 50's, half speed on the electric heater keeps the trailer warm enough so the furnace rarely goes on. If temps are below freezing, we run the heater at full power and make sure there is nothing flamable around the electric heater.
handn is offline   Reply With Quote
Old 02-10-2010, 08:30 PM   #17
DreamStreamr's Avatar
2005 25' International CCD
Fleetwood , North Carolina
Images: 38
Send a message via Skype™ to DreamStreamr
Electrical Codes prohibit any type of extension cord inside your home for resistance heaters. The current draw on electric heaters (and other electrical appliances with resistance elements like toasters, coffee pots) is too high for most home-type extension cords. The high current draw can soften and melt the insulation and create dangerous fire hazard in your home or RV.
Every rule has an exception, and many people survive unsafe things. Increase your chances of survival through safe practices.
Chasing 75 Degrees,
Jim N5RTG
dreamstreamr.com
DreamStreamr is offline   Reply With Quote
Old 02-11-2010, 10:20 AM   #18
Wise Elder
Jammer's Avatar
2010 30' Classic
Well, if your trailer wiring has any problems that should find them.
Old 02-12-2010, 07:32 AM   #19
Cobourg , Ontario
I don't think you would have any occasion to use an extension cord inside a trailer. I think they must have been asking about the cord connecting the trailer to power.
That cord is a special heavy duty one, well up to the job of powering an electric heater. An air conditioner draws way more power than a heater. Not to mention all the other electrical appliances you might use. The electrical system has plenty of capacity for a heater.
Old 02-15-2010, 05:39 AM   #20
Images: 38
Ganaraska,
We were rallying this past week and saw folks running 50' 14-3 extension cords as extensions beyond their 30' 10-3 power cord. But they monitor for voltage drop and we encouraged them not to pull AC for fridge, space heater, microwave, etc.
Good observation about the short cord distances inside the trailer, and I like your answer.
in Okeechobee, FL
Chasing 75 Degrees,
Jim N5RTG
dreamstreamr.com
electrical, heater, winter living
Electric Horn wiring diagram on a 345 John H. Classic Motorhomes 17 07-07-2019 06:46 AM
No LP - All Electric, is it realistic? J.air.doe Electrical - Systems, Generators, Batteries & Solar 40 02-07-2015 05:40 AM
Adding Electric Heater to Atwood ElliotA Water Heaters, Filters & Pumps 4 05-19-2013 01:53 AM
Am I Stupid? Water heater gas and ELECTRIC THEPILL Off Topic Forum 25 10-21-2011 05:08 PM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
