Old 11-29-2016, 10:04 AM   #21
HowieE's Avatar
Princeton , New Jersey
Images: 12
Originally Posted by CruizinDux View Post
I agree with ORTA15 re the successful use use of air pressure and not requiring the use of AF. Granted my experience is much more limited than many on the forums but the 5 or so winterization's have so far been successful.
The one caution against not using antifreeze is the fact that purging with air will not remove the water in the pump or the filter just before the pump. Both are hard fixtures and do not have the forgiveness to freezing that plastic pipe has.
2004 Excursion 4x4
Old 11-29-2016, 11:37 AM   #22
Sag Harbor , New York
Correct, which is why I said this before:
Originally Posted by OTRA15 View Post
The pump and supply line from the fresh water tank require manual procedures not germane right now.
Old 11-29-2016, 02:50 PM   #23
CruizinDux's Avatar
Washington , Missouri
Thanks Peter for clarifying. I was speaking of the CW lines and fixtures themselves. Obviously the pump and it's supply line from the tank require special dispensation.
I think I'm getting a 1/2 male fitting with some tubing...having trouble getting this 'ol body down to the pump house elevation to clear the line back to the tank. A rag is sufficient for catching any residual pump water on the outflow side.
CruizinDux is offline   Reply With Quote
Old 11-29-2016, 05:28 PM   #24
Originally Posted by Rgentum View Post
Where's the air going???
Wondering if you have narrowed down the possibilities here?
Peter
Old 12-01-2016, 05:01 PM   #25
Rgentum's Avatar
2016 27' Flying Cloud
Olympia , Washington
Thank you, responders, for all your suggestions & recommendations. I appreciate your generosity.
Initial comments:
1. The air hose was connected to the "city water" inlet.
2. I used a portable, "pancake" air compressor. When I connected it to the AS, I set the compressor at 50 psi & turned it on. The compressor was never able to maintain more than 20 psi.
3. In my initial post, I said that I had turned three valves on the back side of the hot water heater. Upon checking, I had turned only one, with a yellow plastic handle, turning the handle perpendicular to its line, diverting the intake water away from the hot water heater.
Further comments.
1. I disconnected the distal end of a short, flex hose on the back of the hot water heater.
2. I substituted for the pancake compressor a 1.5 hp compressor, set it at 40 psi, and ran it, connected to the water inlet of the AS.
3. No air was forthcoming from the disconnected flex hose.
4. I checked the trailer's various water valves & found that the outside shower's cold water valve was open & air was coming out of the shower head. I closed the valve.
5. Air was now coming out of the disconnected flex hose, which I reconnected to its socket.
6. The compressor was maintaining 40 psi.
7. When I opened any water valve of the trailer, air came out.
8. I closed all the water valves & disconnected the compressor.
Air blowout now completed. Thank you again.
Richard Wills, Olympia, WA --- WBCCI 8873, WL7Z
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
RIP "BigDog": M Harlequin Great Dane, 150 lb
"St. Rocco": M Black Great Dane, 150 lb
Rgentum is offline   Reply With Quote
Old 12-03-2016, 10:00 PM   #26
CruizinDux's Avatar
Originally Posted by Moflash View Post
Please tell us the difference in 30lbs of air pressure and 30 lbs of water pressure in relationship to a Pex system.Lol
from a recent thread I would have guessed they were the same
https://www.physicsforums.com/thread...ghness.142407/
( http://www.airforums.com/forums/f458...on-144198.html )
Old 12-04-2016, 08:44 AM   #27
HowieE's Avatar
Images: 12
We are getting very close to Over Thinking this issue. The purpose of blowing the water out of the system while winterizing is just that, blowing it out. We are not attempting to reach a state of the absence of water but rather reducing the amount of water to a point that it poses no threat of braking a pipe or faucet. You will never get all the water out unless you heated the trailer to the point of evaporation or pulled a vacuum on the system to the point the water itself boiled off.
2004 Excursion 4x4
Old 12-04-2016, 09:19 AM   #28
CruizinDux's Avatar
I included the link as I thought the discussion of the tankless inflator vs the tanked compressor (pressure up first vs open valve first) was interesting.
Old 12-10-2016, 03:41 PM   #29
2013 23' Flying Cloud
Bainbridge Island , Washington
For now I would let the air pressure fill the water heater [drain plug in, and blow-off valve closed], so that you can use this air pressure to clear the hot water lines in all of the trailer.
How about just closing the water heater bypass valve? isn't that what it is there for?!
2013 Flying Cloud 23D
2001 BMW X5 4.4i (TV)
2004 BMW 330/Ci 6-spd
2005 BWM R1200ST
1977 Cessna C177B
warmrain is offline   Reply With Quote
Old 12-10-2016, 05:29 PM   #30
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
N
Yep.
Mike
Caffeinated is offline   Reply With Quote
Old 12-13-2016, 06:33 PM   #31
Arnoldter's Avatar
2016 27' International
Frisco , Texas
I have a 2016 27 FB. I went through all the steps today to winterize, but I could not get antifreeze to run out of faucets. I had 2 gallons of antifreeze I pumped through the water pump at the intake side directly into pump. Is there a different place to pump antifreeze in?When do you open facets? With pump running while draining antifreeze bottle? How many valves are there to turn on hot water bypass, I saw only one. Low point drains were closed. Thanks for any suggestions.
Arnold and Amy Terkel
2016 27FB
2021 Chevy Silverado 2500;6.6 gas
Arnoldter is offline   Reply With Quote
Old 12-13-2016, 07:05 PM   #32
HowieE's Avatar
Images: 12
If you pumped more than a gallon of antifreeze into the system you still have the hot water heater inline.
There used to be one valve in the bypass line but I suspect Airstream has taken the cheaper way out and now uses 3 valves, all of which will be on the back side of the heater. Set the bypass valves, the handle indicates flow or stopped. Drain the water heater. Then blow out the system one faucet at a time till you get mist. Now pump antifreeze in while opening one valve at a time, starting with the closest valves to the pump. You should see antifreeze almost at once. Continue till all faucets and toilet show antifreeze. Pour antifreeze into each trap, about 6 oz. and cove the flapper in the toilet with a 1/2 in of antifreeze.
You should be able to do this with just 1 gallon.
2004 Excursion 4x4
Old 12-14-2016, 08:06 AM   #33
Datapoint: my 2013 FC 23D still had the 1/4 turn hot water bypass valve.
2005 BWM R1200ST
1977 Cessna C177B
Old 12-14-2016, 02:40 PM   #34
Arnoldter's Avatar
Frisco , Texas
Thanks I missed a valve shut off on hot water heater.
2016 27FB
What happens/how do I know holding tank is full? nmeyer Waste Systems, Tanks & Totes 11 10-17-2010 05:18 AM
Note; Read forum before this happens to you! 2wheelin General Repair Forum 38 02-06-2010 08:14 AM
Good news happens! camperski Our Community 6 10-27-2009 01:41 PM
Turn The Key And Nothing Happens Chaplain Kent Mechanics Corner - Engines, Transmission & More... 102 04-20-2009 07:02 AM
Ouch! What happens when an Argosy MH meets the back of a dump truck 66TradeWind Airstream Motorhome Forums 13 08-12-2002 02:49 AM
