Old 11-30-2024, 07:17 AM   #1
wmb
2013 25' Flying Cloud
Winterizing with a broken/patched low point drain?
We're full-time and follow warm weather, so we've never needed to winterize, but now we're planning an extended trip in Europe so we need to winterize. We're going to be parking up in Austin TX, so it'll be mostly above freezing, but we do get the occasional multi-day cold snap.
During the last such cold snap a few years ago, the low point drain valve on the hot water side cracked and started leaking, then broke off entirely. We patched the pipe with some epoxy, initially as a temporary measure, but never actually got around to getting a new valve fitted.
We're planning to use compressed air to blow out the lines as much as we can, then use the pink stuff, but we're not sure if that will be good enough with the now blocked low point drain pipe.
Will blowing out the lines with air be able to clear water from that blocked downpipe, or do we need a plan B?
wmb is offline   Reply With Quote
Old 11-30-2024, 07:57 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I think you will be okay if you blow out the lines and then put the pink stuff in the lines. If you just blow it out there will be water in the low point line and it will freeze and might break. If you blow out and then pump pink I think it will mix in with the water left in the lines well enough. I do not use my low point drains. I just blow and put in the pink and have been okay for 15 years in Tennessee.
Low point drain broken Airstream 65 Fresh Water Systems 17 10-19-2021 09:50 AM
Low point drain broken Gmutt General Repair Forum 4 02-20-2017 11:54 AM
Winterizing snafu - low point drain valve on FW tank stripped and won't opem bonginator Fresh Water Systems 12 09-29-2013 03:22 PM
Replacing broken low point fresh water drain 2010 28' FC kentuvman Fresh Water Systems 0 12-28-2012 10:11 AM
Can PVC /Plastic be patched Chitown AirStreamers Waste Systems, Tanks & Totes 1 07-05-2010 12:16 PM
