11-02-2022, 05:04 PM
S/OS # 023
2005 28' Safari S/O
Indianapolis
, Indiana
Winterize - Pump will not draw Antifreeze?
I have a 2005 Safari LS Slideout 28'
I have installed a winterizing valve at the inlet side of the pump - The pump has worked flawlessly for fresh water - I always blow out the lines and all fixtures with compressed air before starting to add antifreeze - after turning the diverter valve when I try to draw antifreeze in through the pump it will not draw I have tried a funnel to prime the pump it takes what I pour in but it will not draw from the bottle
Any ideas?
PovIndy
11-02-2022, 05:16 PM
1994 34' Excella
Warren
, Manitoba
Do you have a tap open? If nothing is open it will not pick up the antifreeze!!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
11-02-2022, 05:35 PM
2016 16' Sport
Miami
Are you sure you did not install the valve backwards? They are one way and its an easy mistake.
11-02-2022, 05:43 PM
2017 28' International
Jim Falls
, Wisconsin
My thoughts. Fairly easy to do.
11-02-2022, 05:46 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
It’s installed backwards. Been there done that.
11-03-2022, 10:17 AM
2019 23' Flying Cloud
Port Colborne
, Ontario
Valve in backwards
I think you have the valve in backwards.
I bought a new 2019 Fc and had the exact same problem.
I called the dealer and they never even bothered to return my call.
Pour anti freeze into the clear plastic tube and then drain the tank to see if anti free come out. This is how I discovered the the valve was in backwards.
The valve handle should face in the correct direction.
I removed the valve and reversed it and everything worked.
Keith S
11-03-2022, 01:29 PM
2019 27' Globetrotter
McHenry
PovIndy, once you verify the valve is installed correctly make sure the fittings on the pump are tight. Any air leak can keep the pump from pulling a vacuum.
I had trouble getting mine to draw from a bottle too. I found a Hopkins FloTool funnel with a shutoff valve. Turns out the valve’s threads match the bottle. I made a stand to hold the bottle upside down so gravity helps it prime.
NOTE: Put a vent hole in the bottle so it doesn’t collapse. I cut a hole in the bottom and just poured more in when needed. I used some quick clamps to hold it when opened the faucets.
If you don’t want to mess with a stand, have someone hold the bottle for you.
Works for me!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
11-03-2022, 03:28 PM
The Aluminum Tent 3
Park City
, Utah
Many ways to skin a cat, but if everything is working correctly the pump will easily pull from the AF jug, upright. After all it pulls from the fresh tank just fine, which is lower and farther and doesnt need ‘priming.’ If the pump won’t pull from the bottle, then you have a bad connection at the pump or winterizing valve. A 1 gallon jug should get sucked dry in a minute or less.
11-09-2022, 12:31 PM
2022 16' Bambi
Central City
, Iowa
Factory installed winterizing valve backwards
Just tried to winterize my new 2023 Bambi. Airstream installed the valve backwards. Pump would not draw antifreeze. I reversed it, and now it works correctly.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Winterized, De-Winterize, Then Winterize Again
Hoagie |
2016 - Current Classic (all lengths) |
20 |
12-12-2018 02:01 PM |
Winterize with just antifreeze
Atsushi |
Winterizing, Storage, Carports & Covers |
9 |
11-08-2017 02:45 PM |
Pump in RV Antifreeze Downstream from the Water Pump?
KJRitchie |
6 |
01-09-2015 02:18 PM |
Winterize, Pink Stuff, RV Antifreeze, Drain and Flush
masseyfarm |
Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes |
12 |
11-19-2013 07:40 PM |
Time to Winterize - Save on RV Antifreeze...
mountainman1 |
Plumbing - Systems & Fixtures |
0 |
10-18-2011 07:30 AM |
