Pioneers still exist! Wonderful examples with Tent and Airstreams.
We have prepped our 2019 Oliver Elite II trailer since purchase. We have been careful to compare how the Oliver organized the water and heating systems within the living area, smaller than a 23 foot, but a close example, as we had a 23 foot Safari.
The WATER and HEATING systems are together under the curbside couch area, within the living space. The Heat also vents from this area and in the process adds heat to the water lines and fresh water tank that is distributed over a large area below the floor and appears above the aluminum alloy frame.
Very smart and frame / support / water tank / black & grey water, body and insulation designed for Colder Weather Oliver RVing. The previous Oliver Owner was wise to have purchased an extra WATER PUMP as the entire water system is operated by opening and closing water lines to fill, add and use. Nancy is the 'inside person'... and I am safely watching from a distance.
This has been an interesting time consuming Airstream and Oliver prepping for 2022 Season. Both trailers are humming, operating and ready.
NO popped interior RIVETS in the 27FBQ. Even have the Entry Door closing and opening easily... imagine that. Even insulated the entry way with Gorilla Tape strips to fill in the gaps around the entry frame and even sealed the Rear Cargo Area... for once. Adding some gaskets on the open side spaces and hardware to secure this area to the rear bumper better. No water to freeze, if it cannot enter.
Keeps me off the Forum, and getting tow vehicle and trailers tweaked for another interesting serious of adventures... of some sort or other.
We shall see. After spending much time prepping, learning a new way to bring fresh water into and out of the Oliver... we are now catching up to our Airstream knowledge. The two trailers have Double Axles and 16 inch Michelins in common... The Oliver has leaf springs attached to straight axles.
We will try to do what several Airstream owners have experienced in Cold Weather Conditions. The Oliver is better insulated for Heat and Cold, compared to our 27FBQ.
The Oliver IS a four Season Trailer. The Airstream, three Season... and may just respect that bit of one Season for ONLY an Oliver... The Oliver is much better insulated for Winter conditions and very well thought out with the limited space within. Just shy of a 23 foot, considering storage is also very well placed for space.
Call us Airstream Happy and Oliver Happy. Both have the 30 Pound Propane Tanks... Ian Poulin and Mattedfred give me courage. Will enjoy this Season with both trailers... and then... test the Oliver for "Believe It or Not" Fourth Season use.
This will be a Two Blue Heeler Winter for us this year.
