Old 02-05-2023, 06:41 PM   #1
2022 16' Basecamp
Mesilla , New Mexico
When is it safe to de-winterize
I will be picking up my new Basecamp 16 RV sometime in the next month. I am new to rv-ing, so I'm wondering when it is really safe to de-winterize it. I live in southern New Mexico in the desert. We can get freezing nights on and off well into March. I will not be living in it but will be doing weekend and vacation travel. So should I wait until we get past the "official" last day of frost (March 20)?
Thanks for your advice!
lcschultz is offline   Reply With Quote
Old 02-05-2023, 07:27 PM   #2
Jeff7176's Avatar
2018 25' International
Full-time , Traveler
First, congrats on your new Basecamp. We’re in ABQ now and will head up to Santa Fe in a couple weeks. We full-time and generally try to stay where it’s warmest, but my wife is an avid skier so we end up in cold locales every year. Living in it actually makes things easy. We don’t hook up a water hose, but fill the fresh tank and use that. We set the furnace to 55 at night and it works well.
Before we were full-time, we lived in DC and still camped year round. When we finished a winter trip we would drain the fresh tank, open the low point drains as well as the water heater drain, and then use our air compressor to blow the lines of most of the water that may have been left behind. We never used antifreeze and always camped 12 months a year.
Jeff7176 is offline   Reply With Quote
Old 02-08-2023, 11:34 AM   #3
2017 25' International
West Lake Hills , Texas
We camp fall, winter, and spring. Trailer is in storage when not I use so we winterize with compressed air only. We don’t dewinterize for short trips alone. Use five-gallon water jugs plus a one gallon at the toilet. If going on a short trip with a grandchild we use the fresh water system and winterize again. While camping in freezing temps on longer trips we use the fresh water system and keep the furnace set to 50*F or higher.
Fungus is offline   Reply With Quote
Old 02-08-2023, 11:57 AM   #4
2022 25' Globetrotter
Madison , Alabama
The general rule of thumb I've always heard is that it takes around 24 hours at 32 degrees for water to freeze in a pipe. When it gets into the 20s, it can happen in 6 hours or less and in the single digits/teens, in 3 hours or less.
If you don't have plans to use your trailer, definitely wait until April to de-winterize. If you do plan to use it, make sure you're full up on propane, de-winterize, and keep an eye on the projected overnight temps. If it looks risky, plan on running your furnace until it warms up. Just be aware that if you run out of propane, you could have an expensive disaster on your hands.
Tyler2you is offline   Reply With Quote
Old 02-08-2023, 12:40 PM   #5
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
Safest time to d-winterize is after the last frost, during shouldering periods and your trailer is nearby and you have access to it and electric or solar is available to replenish your battery bank then monitor the temperatures and use your propane to keep it above freezing.
Silvr_Bullet is offline   Reply With Quote
Winterized, De-Winterize, Then Winterize Again Hoagie 2016 - Current Classic (all lengths) 20 12-12-2018 01:01 PM
Gun/Valuables Safe - What safe is the best? BrandonJenna General Interior Topics 22 02-21-2013 12:24 PM
1973 23' LandYacht Safari Purchase / Winterize?? Sampsel Winterizing, Storage, Carports & Covers 5 11-07-2002 08:12 PM
How to winterize when you're fulltime? escapeez Winter Living 2 09-15-2002 04:06 PM
