12-08-2017, 06:19 AM
#21
1995 25' Excella
xxxxx
, xxxxxx
If you don't blow out or put in antifreeze, I feel certain you will be replacing your toilet flush valve in the spring.
12-08-2017, 08:17 AM
#22
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village
, Arkansas
If you use air to blow out your plumping system in lieu of pumping in antifreeze, how do you winterize the water pump? I don't see a way to blow air through the pump.
Rick
2017 27 Tommy Bahama
2020 2500 GMC Duramax
12-08-2017, 08:26 AM
#23
1960 28' Ambassador
Libertyville
Originally Posted by carl2591
got a quick question on blowing out lines..
If you open the low point drains, open faucets and drain water out of line how is that different or why is air pressure better?? freezing water causes issues when in a confined space not allow to expand as water does when it freezes.
Seems to me is you get 99% of water out of system, remove water pump, leave faucets open, low point drains open, water heater drain open, the effect of freezing expanding water is eliminated..
is that not true. ??
I am always surprised at the amount of water that comes out when using air pressure even after opening the low point drains and faucets.
12-08-2017, 10:00 AM
#24
Hot Springs Village
, Arkansas
Rick
Sorry, meant to write plumbing system and I don't remember how to edit a post.
12-08-2017, 11:53 AM
#25
1995 25' Excella
xxxxx
, xxxxxx
Rick
My manual says to take the lines off and let it drain.
12-09-2017, 06:30 PM
#26
South East
, Michigan
This year, I let all my water drain out. Then I connected my compressor. I easily got another 2 quarts of water out. I suspect there are a number of dips in the water lines that hold water.
Al
2017 29' SOB, 2022 Platinum F-150 SCrew, ProPride
12-09-2017, 09:45 PM
#27
Washington
, Missouri
I disconnect the output and run the pump catching the cup of so in a towel. I also attache a 1/2 NPT male adapter with a hose and screw into the input connect to blow moisture back to the tank, then switch it to the out line to move any moisture further down the line to the LP drains.
p.s. I use a compressor to blow the lines out. If at home I use a larger dual tank that is overkill. Before that I used a 110VAC inflator that worked fine. In a pinch I've used a 12VDC inflator when on the road. I do not use AF except in the traps/head.
Here are 2 recent threads but there are a zillion ones inn the search function.
http://www.airforums.com/forums/f458...ml#post2041387
and
http://www.airforums.com/forums/f458...ml#post2034478
