Old 06-21-2021, 12:37 PM   #1
Tifmartin109
1970 31' Sovereign
2010 30' Flying Cloud
Tunkhannock , PA
Exclamation Water Heater De Winterizing
Hello!
We have a new to us 2010 flying cloud. We bought it last year. This winter was our first time wintering a AS. We are concerned about the water heater now that we are opening the trailer back up for the season.
We drained the water heater in the fall. We never switched off the breaker to the heater. Not sure if that matters.
We refilled the fresh water tank and hooked it up to city water as well. The faucets are flowing but no hot water.
I'm not sure how to refill the water heater.
I turned on the switch in the bathroom and the red light did not come on. I assume that is a good thing and that it is igniting. Not sure if turning the switch on has caused damage because there may be no water in the heater. I only turned it on then right back off.
Attached is a picture of our water heater.
tifmartin109 is offline   Reply With Quote
Old 06-21-2021, 12:44 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Do you have a WH by pass valve? Our WH fills up if I open a hot water valve and connect the water supply. If...the by pass valve is in the correct position.
Old 06-21-2021, 12:48 PM   #3
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
Ok, I am making a few assumptions here:
1) Pump and/or city water is on/connected flowing
2) The water heater is on and LP valves are on and you bled the line and stove lights
2a) If heater is electric, verify it's on, heating and no tripped breaker.
3) Water heater is lit and actively heats water.
From there, I would look for the three valves that bypass. Supply and output valves turned counter clockwise, center bypass valve turned counter clockwise disabling the bypass.
By having valves turned as suggested, water pressure automagically fills water heater.
panamerican is offline   Reply With Quote
Old 06-21-2021, 01:12 PM   #4
Tifmartin109
1970 31' Sovereign
Tunkhannock , PA
We never put in antifreeze. Only drained the water lines, fresh water tank, and emptied the water heater. Because of that we have never touched the bypass valves. I checked the release valve on the water heater and water did come out. I assume that means the water heater is full. We are not currently using LP only the electric. I flipped the electric switch on in the bathroom and I think I can hear the water heater running, but still no hot water. I'm confused LOL
Old 06-21-2021, 01:42 PM   #5
Dennis C's Avatar
Evergreen , Colorado
Is the water cold, or does it run warm for a little while and then turn cold? Or does no water come out when you open the hot water taps?
Dennis
Newmar Ventana 3715
6,265 lbs. cargo capacity
Dennis C is offline   Reply With Quote
Winterizing / De-Winterizing Adventure.AS Winterizing, Storage, Carports & Covers 18 11-03-2021 01:28 PM
De-winterizing with my new winterizing kit installed PatLee General Interior Topics 12 01-23-2020 05:55 AM
De-Winterizing & Winterizing after short trip to TX Jasper14 Winterizing, Storage, Carports & Covers 6 01-20-2020 02:31 PM
De-Winterizing - Water Heater Issue redvfr02 2005 and newer - Bambi all models 21 04-19-2017 09:04 AM
Question on winterizing water heater mandolindave Winterizing, Storage, Carports & Covers 13 10-31-2015 08:05 AM
