Old 11-21-2021, 10:41 PM   #1
South Jordan , Utah
Water coming out when pump is on
We just took delivery on our 2022 Flying Cloud 30ft Bunk and on our maiden voyage we stopped at a Walmart and “drycamped”. Whenever the water pump would come on, water would come out of this white tube. Any ideas on why that is happening and how to stop it? The rig came winterized and after the dealer inspection it is no longer winterized.
mrhankuk is offline   Reply With Quote
Old 11-21-2021, 11:13 PM   #2
2007 27' Safari FB SE
NW Oregon in a nice spot , Oregon
My guess is they left the main water drain valve after the water heater open to release moisture. Check the valves around your water heater to be sure the main drain is closed. Not a big worry, just figuring out the required valve open and closed positions.
bweybright is offline   Reply With Quote
Old 11-22-2021, 10:58 PM   #3
2018 30' Flying Cloud
Huntsville , Alabama
Take a look at the following two posts. The tube will be the macerating toilet drain or the water heater drain
What is this pipe for?
https://www.airforums.com/forums/sho...d.php?t=206625
30 Bunk Drain tube
https://www.airforums.com/forums/sho...d.php?t=216697
143pm is online now   Reply With Quote
Old 11-22-2021, 11:10 PM   #4
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Welcome to AirForums! We are glad to have you with us.
I think the earlier replies will have answered your question.
I hope you enjoy your trailer as much as we enjoy ours.
SSquared is offline   Reply With Quote
Old 11-22-2021, 11:39 PM   #5
South Jordan , Utah
Thanks everyone! We’ll take a look
Water coming out city water inlet mutcth Fresh Water Systems 7 11-02-2021 04:31 PM
Ice coming out of vents when turned on heat pump Kriswin 2016 - Current Flying Cloud 10 10-18-2021 04:41 PM
Water coming out of city water outside hookup after I turn on my pump Joeb Plumbing - Systems & Fixtures 5 06-19-2018 06:51 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 07:46 PM
water coming out pressure regualtor drain line when on city water txstreamer Fresh Water Systems 7 09-16-2010 04:07 PM
