Old 12-31-2020, 07:14 AM   #1
2021 25' International
Ottumwa , IA
Viair setting
Preparing to winterize for the first time before returning to Iowa. 2021 International 25FBT. How do I "set" pressure to 50 psi for blowing air? I read that as soon as a faucet is opened the pressure will go down to 0. How do I know what is too much? I'm on the fence about pumping AF. Talked to Jackson Center and they said blowing air and removing plastic filter cover on the water pump was enough. Thoughts?
Jeff Bittner is offline   Reply With Quote
Old 12-31-2020, 07:19 AM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I have a viair, use it for my tires.
It does not produce the necessary constant pressure / flow / volume necessary for winterization. I use a 6 gallon compressor for winterization.
On another note, you cannot regulate constant pressure on the viair. For tires you use the gauge and stop filling air when you reach your desired pressure.
wulfraat is offline   Reply With Quote
Old 12-31-2020, 07:39 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
What he said. I learned the hard way that the only thing that can really keep up has a tank. I bought a Porter Cable pancake compressor and it does a fine job. I really need it for my tires as well, truck and trailer, rather than wearing out my VIAIR before I leave on a trip. My VIAIR is great for those changes needed when out on a trip.
Larry
lsbrodsky is offline   Reply With Quote
Old 12-31-2020, 08:20 AM   #4
"Cloudsplitter"
The VAIR is not designed for continuous operation.
Even our 450rv must rest after 45min.
I have seen a portable tire compressor used to fill a 40gal LP tank and that used to blow lines, an even more time consuming job.
Best to buy a portable compressor...
Old 12-31-2020, 08:29 AM   #5
SailorSam205's Avatar
South East , Michigan
I use my Viair to get the majority of water out of my system. I do have a 2 gallon accumulator tank installed to cushion the air/water pressure. I also have a ball valve on the hose that I use to attach to my trailer. I get everything set up with the valve closed and pump on. Then I open the ball valve and steadily go thru the trailer opening and closing my faucets and toilet. Once I am almost dry, I leave the last faucet open and turn off the pump to clear all pressure. Then I close the valve at my accumulator tank and pump in antifreeze, I don't want to get antifreeze in the tank. I like the added insurance that having pushed antifreeze into all the spaces in the faucets and water pump. Haven't had an issue with plumbing since following this routine.
Al
2017 29' SOB, 2022 Platinum F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 12-31-2020, 11:19 AM   #6
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
I use my VIAIR fir blowing the lines. it will work fine. After draining the system close all faucets and pressurize to 40-50 PSI. Open one faucet at a time and re-pressurize between openings. Also blow out the low points and the black tank flush and outside shower.
I purchased their winterization kit that has an air regulator. In fact you can blow out your lines with a bicycle pump - it just takes a bit longer.
Check out this YouTube from TheFitRV.
https://youtube.com/playlist?list=FL...hB32dnoKakg27A
Ray B.
Adventure.AS is offline   Reply With Quote
Viair 450P urnmor On The Road... 0 06-22-2018 02:33 PM
Viair 450 no good for winterizing? Philip Jones Winterizing, Storage, Carports & Covers 21 03-28-2018 06:38 PM
VIAIR Questions AIRHEDS Winterizing, Storage, Carports & Covers 3 11-14-2016 05:41 AM
Viair 400P-RV automatic portable compressor kit copenagle Airstream Classifieds 0 10-14-2016 04:50 PM
Viair 88p 12v air compressor. Caffeinated Tires 5 07-14-2016 09:06 AM
