Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 10-24-2020, 02:20 PM   #1
2021 25' Globetrotter
santa Fe , New Mexico
Tankless Water Heater Winterization
My new 2021 GT 25FB has a tankless water heater. To winterize with compressed air, is there a valve to open ( like the tankless ) first?
wheelman is offline   Reply With Quote
Old 10-26-2020, 07:03 PM   #2
2020 22' Bambi
Mountain Green , Utah
Location of Valve on 2021 with tankless
Yes! I literally just had our 2021 25FB FC winterized this past Friday. I took both video and photos of the location. Ours is passenger side towards the front. There is a a small valve on the right side of the heater accessible through the front storage compartment. Open it and the tankless water heater will drain through a short hose (1/2” maybe?) that comes out of the bottom of the trailer. You could also look under the trailer for a short drain hose.
Hope this helps!
DougCharli is offline   Reply With Quote
Old 10-27-2020, 09:17 AM   #3
2021 19' Bambi
Undisclosed , New Mexico
I have a 2021 Bambi 19CB with a tankless water heater. We're having a cold snap and it's currently snowing, hovering at freezing temps but expected to warm backup in a few days and I have plans to hit the road. Currently, the tanks are empty and I put insulation around the grey/black tank outlets outside the rig and towels around pipes of the toilet and sinks. What should I do to the tankless water heater outside to keep it from getting damaged?
I'm currently making it my home office so I'm working in it now and have the heater on low as well as a small space heater going. When I first came in this morning, the water heater display by the sink was reading "E1" but has since gone back to normal. Hopefully, there was no damage done overnight.
Any feedback welcomed!
wndrlst4life is offline   Reply With Quote
Old 10-24-2021, 10:02 AM   #4
2021 23' Globetrotter
Albuquerque , New Mexico
Question Winterizing tankless water heater
I have a 2021 gt 23 twin and cant find a low point valve to open to blow compressed air through it. Does one exist on it? Or do i just open hot water faucet?
ScottT is offline   Reply With Quote
Old 10-25-2021, 08:38 AM   #5
2021 19' Bambi
Baraboo , Wisconsin
Ask an Airstreamer: Winterizing (inc. tankless water heaters)
We found this to be really helpful, especially the section on tankless water heaters. The Girard does not require any additional steps, which was good to know.
6:27 - How to find your low point valves
11:00 - water heater specific information
Good luck!
StreamRunner is offline   Reply With Quote
Old 04-07-2022, 07:51 AM   #6
Moscow , Idaho
Does anyone have advice for insulating and/or adding a bit of a heating strip/pad their tankless water heater to help protect it against frosty days? We want to be able to get the season started earlier (and run longer) prior to winterization and - given that the Girard system is in a box outside of the other insulation - it seems to be the weak spot for the trailer. Thoughts?
Chris
(2022 International 27FB)
2022 27FB International
Moscow, ID
chris_marx is offline   Reply With Quote
Winterization / water heater bypass valve Schiappiv Winterizing, Storage, Carports & Covers 11 10-02-2019 01:17 PM
Space Heater for Winterization jjagnew Winterizing, Storage, Carports & Covers 6 09-18-2010 01:38 PM
Tankless water heater FC54 Water Heaters, Filters & Pumps 20 10-27-2004 03:18 PM
Winterization Blues - Water Heater Question BrianRegan Water Heaters, Filters & Pumps 0 06-13-2004 11:36 AM
Tankless water heater spinolio Water Heaters, Filters & Pumps 3 12-21-2002 09:53 PM
