Old 04-03-2022, 12:48 PM   #1
2015 25' Flying Cloud
Redmond , Washington
Stabilizer Jacks While in Storage
Driving through our storage lot the other day, I noticed at least half of the Airstreams stored there had their stabilizer jacks down. Why? Is there some advantage to using stabilizer jacks while parked in storage that I am unaware of?
McStreamy_ is offline   Reply With Quote
Old 04-03-2022, 12:57 PM   #2
2018 30' Flying Cloud
Springfield , Ohio
I can't think of any advantage to lowering the stabilizers. Do be sure to chock the tires though. Strong winds can push the trailer forwards or backwards which can be a problem.
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
tbrowne is offline   Reply With Quote
Old 04-03-2022, 02:04 PM   #3
1979 31' Excella 500
Mojave , California
Personally I would in case the tires loose pressure, maybe also if you want to keep the trailer leveled
My 79 Excella 500 31ft rebuild:
https://www.airforums.com/forums/f20...ld-224367.html
Sylvain is offline   Reply With Quote
Old 04-03-2022, 02:51 PM   #4
Dennis C's Avatar
Evergreen , Colorado
I tend to do projects and/or repairs on my Airstream wile it’s in storage. I don’t want it bouncing around while I’m doing those things, so I put my stabilizers down. I think it would be fine without lowering the stabilizers, but I always put mine down.
Dennis
Dennis C is offline   Reply With Quote
Old 04-03-2022, 03:15 PM   #5
Escape Pod II
John Ware's Avatar
2022 23' Flying Cloud
2018 22' Sport
Orange , Texas
If your tires go flat, you don't want the stabilizer jacks holding up the trailer.
JEWare
John Ware is offline   Reply With Quote
Old 04-03-2022, 03:42 PM   #6
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Tavares , Florida
Agreed!
Old 04-04-2022, 06:26 AM   #7
This makes sense. I do projects while my trailer is stored as well but hadn't ever bothered to put the stabilizers down.
Old 04-04-2022, 06:32 AM   #8
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I use to however have not done so in years after I noticed they were not down at the dealer. I do use a chock
urnmor is offline   Reply With Quote
Old 04-04-2022, 10:35 AM   #9
Mojave , California
Why? Am I missing something?
Old 04-04-2022, 10:46 AM   #10
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If you use the stabilizers and you loose tire pressure, it will put additional weight on the stabilizer which in turn can warp the frame. If you were to try and jack the trailer with the stabilizer you might find it impossible to open and close the main door correctly. This is do to the frame being warped by the weight on the stabilizer.
Richard
Old 04-04-2022, 12:47 PM   #11
1960 26' Overlander
Tipton , Iowa
I would not! Seen too many stabilizers bent up in a storm that didn't do any damage to the non-stabilized trailers.
Scott S is offline   Reply With Quote
Old 04-04-2022, 01:00 PM   #12
Saluda372's Avatar
2021 20' Caravel
Plaistow , New Hampshire
Good advice !
Learning and enjoying as we go !
Saluda372 is offline   Reply With Quote
Old 04-04-2022, 03:09 PM   #13
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Above comments true. Remember they are for stabilizing not lifting. I have a friend with a 30 Classic and has bent his just putting too much pressure on while cranking down to stabilize.
Howard L. is offline   Reply With Quote
Old 04-04-2022, 07:04 PM   #14
Life is a Highway's Avatar
2018 25' Flying Cloud
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake , Florida
True
Was just thinking that. Not good if they turn into jack stands not stabilizers.
Life is a Highway is offline   Reply With Quote
Old 04-08-2022, 04:18 PM   #15
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Assuming the tires will not go flat if you store the TT with stabilizers down it will slow down or deter thieves if they have to crank up 4 jacks before they can steal your rig.
guskmg
Old 04-08-2022, 08:13 PM   #16
2017 25' International
West Lake Hills , Texas
guskmg
With my angle drill it takes me about 10 seconds per stabilizer to crank it up. On high speed it takes five seconds per stabilizer. Counting leisurely travel time between stabilizers...two minutes. Maybe those two minutes make a difference to the hypothetical thieves.
Fungus is offline   Reply With Quote
Old 04-13-2022, 09:34 AM   #17
2019 26' Flying Cloud
Granite Bay , California
I've had a continuing problem with my entrance door not aligning with the latch. This causes considerable difficulty closing the door. I have to slam it shut, well beyond what the "bank vault" closing should be. It's not a "normal" slam and has gotten to the point where I don't latch the door during the day so as to avoid slamming hard it constantly. I've been told by the dealer to be sure to level the trailer while camping as the frame will twist to some extent otherwise. I've also heard from Airstream campers at least once that the trailer should be leveled while in storage for the same reason. I haven't talked to the dealer about this specifically, but intend to. It does make sense, however, to level the trailer during storage if there's a tendency for the frame to twist and cause misalignment throughout the trailer, including, the entrance door.
RayJon is offline   Reply With Quote
Old 04-13-2022, 09:47 AM   #18
Stabilizers don’t level the trailer. Level the trailer at the wheels and the tongue. The stabilizers are intended to mitigate the natural flexing of the torsion axles while the trailer is occupied.
Old 04-13-2022, 10:52 AM   #19
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
I’ve always thought the stabilizers down would just provide four more avenues for critters to enter the trailer. I leave them up when in storage.
I also agree with the statements above about “not” supporting the trailer with just the stabilizers.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
GettinAway is offline   Reply With Quote
Old 04-13-2022, 02:05 PM   #20
2004 22' International CCD
Beaumont , California
Well, the stabilizers are not designed to support trailer weight; and putting them down to support the trailer if a tire goes flat does just that.
I don’t do it.
Ndcctrucks is offline   Reply With Quote
Portable Stabilizer Jacks vs Power Jacks TradeWind222 Exterior Restoration Forum 0 07-07-2021 06:05 PM
Stablizer jacks replacement with scissor jacks spoonplug Jacks, Stabilizers, Lifting and Leveling 21 01-01-2021 05:15 PM
Stabilizer jacks down while I hitched up Thomas_G General Repair Forum 7 11-19-2013 09:52 AM
