Old 05-25-2025, 09:10 AM   #1
2018 30' Classic
Traverse City , Michigan
Spring unwinterizing.
Help. We winterized our Classic for the first time. We’re now opening it up for a trip and unwinterizing for the first time. All water system valves are back in the operating position. Started to run some water to clear the anitifreeze and the bathroom sink won’t drain. The kitchen didn’t for a bit then slowly started to. There’s nothing to turn for winterization. What could be the problem? Any suggestions?
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30’ Classic
SMKovalchik is offline   Reply With Quote
Old 05-25-2025, 09:54 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 199
RE: Sluggish/Non Draining Gray Water Drains
Greetings SMKovalchik!
While both of my trailers are much older than yours, I am only familiar with one change to the gray water drain system that may make the systems much different. The one thing that occurs to me, and that has happened on more than one occasion to me, is that one or both gray water through roof vents has been either blocked or partially blocked resulting in either sluggish or non-draining of kitchen sink, bathroom vanity, and or bathtub/shower. In each case, the culprit has been insects building their nests in the vent during the off season. My problem insects have included, mud daubers (most frequent), paper wasps (second most frequent), and wild bees (only once, and they migrated from my home when they were evicted by exterminators from my kitchen walls). The solution was removing the vent pipe cover on the roof and running a gentle stream of water down the vent pipe to clear the blockage after the offending insects had been evicted. It would also be possible to use a very thin, flexible sewer snake to clear the vent pipe in the same way once the offending insects have been evicted.
I do know that I have heard that some of the more recent model Airstreams use a one-way vent valve in the drain below either the bathroom vanity or the kitchen sink to eliminate one of the roof penetrations for gray line vents, but am not familiar with just which trailers used them and when.
Good Luck in finding your drain issue!!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC/Pride Streamers/Wisconsin-UP Unit (Primary)/Missouri Greater Ozark Unit (Affiliate Member) #7864
AIR #827
1964 Overlander International
Old 05-25-2025, 10:24 AM   #3
Bearstream01's Avatar
2023 25' International
Long Island , New York
Take a look at what direction your pipes run in. Could be as simple as not being level.
2023 Airstream International 25RBT
2019 F250 XLT 6.7L Power Stroke Diesel
14457
Bearstream01 is offline   Reply With Quote
Old 05-25-2025, 10:33 AM   #4
1988 32' Excella
Robbinsville , New Jersey
If your trailer has Hepvo valves instead of traditional P-traps that valve could be stuck shut. You may be able to open it with a sink drain snake or plunger. I would try the snake first make sure to be gentle with it.
Old 05-25-2025, 07:13 PM   #5
2018 30' Classic
Thank you my friends. The kitchen drain suddenly started draining and when it did the bathroom sink suddenly did as well. Hubby gently banged on the drain pipe and it seemed to break something loose. Anyway, we’re off and rolling. Thanks again.
2018 30’ Classic
Unwinterizing Bparkeruga Winterizing, Storage, Carports & Covers 5 02-19-2020 07:23 PM
Front coil spring to air spring conversion. tedly797 Classic Motorhomes 1 05-24-2016 09:32 PM
Unwinterizing tip mandolindave Winterizing, Storage, Carports & Covers 1 05-22-2015 10:30 AM
Hensley Spring Plunger, Grease fitting spring bar retainer dznf0g Hitches, Couplers & Balls 2 08-29-2012 07:43 PM
Need spring load clips for water heater door 68 GT. Jim Clark Water Heaters, Filters & Pumps 4 05-09-2002 07:39 AM
