09-19-2021, 06:35 PM
Evergreen
Shortage of RV antifreeze this fall?
I can't verify the reliability of my source, but I've heard that RV antifreeze is going to be tougher to get than usual this fall. I originally heard this from my brother. I've subsequently heard it from the manager of an auto parts store that carries RV antifreeze. I went to my local Walmart to buy a couple of jugs today, and the shelves were bare. They were completely sold out of the pink stuff. Fortunately, my local Big R store had plenty, so I picked it up there.
I don't know if this news is based in fact or if it's just a rumor, but it may not be a bad idea to pick up a couple of jugs now before you end up in a bind!
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
09-19-2021, 06:43 PM
2017 25' International
West Lake Hills
Don’t need much. Just a pint in each drain. Blow out the lines. Worked fine here at 3 degrees F.
09-19-2021, 07:16 PM
1994 28' Excella
Manhattan
, Kansas
I always buy mine in early spring. and got from Menards at 4 bucks a case with 4 one-gallon jugs.
Dennis & Ellie
1994 Excella Classic Unlimited 28 Foot
2017 RAM 2500 Gas 3170 Payload
and
2017 Newmar Ventana Class A DP 7224 Payload
09-19-2021, 07:20 PM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Easier yet, head south!
09-19-2021, 08:03 PM
diesel maniac
Airstream - Other
Tucson
, AZ
Well if there isn't a shortage now as soon as word gets out that there is then there will be.
Brian
09-19-2021, 08:08 PM
1994 25' Excella
Waukesha
, Wisconsin
Wasn't a shortage at our local Menards - got enough to do the Airstream and my coach recently with not a problem. They had both the -50 and -75 stuff.
Richard
11018
09-19-2021, 08:17 PM
Evergreen
I typically do the same thing.
09-19-2021, 09:05 PM
2021 20' Caravel
Plaistow
, New Hampshire
Shhhh
Learning and enjoying as we go !
09-20-2021, 04:21 AM
2021 25' Globetrotter
Jamestown
, Rhode Island
I have heard that one of the big suppliers of RV antifreeze has left the business. I know that Camco has abandoned the marine supply side. The price is also increasing!
Loving our 2021 Globetrotter 25 and our 2022 Ford F-150 King Ranch 5.0!!! Plenty of payload, not even close to axel limits and it drives and rows beautifully…
09-20-2021, 06:02 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
WHAT....Time for the Zon
But I bought 2gal two years ago and still have enough for this Winter.
I use it to displace the water where it is not where it was.
Blow baby blo.
09-20-2021, 06:53 AM
Oswego
Blow baby blo.
Great! Now compressors will be in short supply!
-Rich-
09-20-2021, 07:24 AM
1972 31' Sovereign
Lexington
The one year we only blew out our lines with an air compressor, and didn't use antifreeze too, we replaced our water pump in the spring. With winter temps occasionally in the minus 20 F range, we need the antifreeze. Different areas of the country can do less, it depends on temps. There's not a blanket solution!
Kay
09-20-2021, 07:34 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Kay
Gets cold here in WNY also...
But, I always include the WP when I blow out the system. SFSG
09-20-2021, 07:39 AM
1994 28' Excella
Manhattan
, Kansas
I did just that for a lot of years but I had a 5er that the low spot was 90 degrees elbow that was the lowest spot in the system. Water drained back into the elbow and froze and cracked the elbow. Now I blow out the lines and then added the antifreeze.
Dennis & Ellie
and
09-20-2021, 07:54 AM
diesel maniac
Airstream - Other
Tucson
, AZ
Wouldn't cheap vodka work?
Brian
09-20-2021, 07:56 AM
Oswego
Maybe. IIRC, vodka freezes at -17*F.
-Rich-
09-20-2021, 08:01 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Yes, but in spring how much has evaporated.🥳
09-20-2021, 09:29 AM
2005 31' Classic
Garner,
, North Carolina
i was just draining the lines, drain the WH, open both low point open faucets.. did the blow thing as well some years..
most of the time water in a elbow will expand and not crack them but you can never tell.. keep the air blowing for 5 to 7 mins with help push the water out so very little remains in places like 90's..
we pour about 3 oz in drains as well.. or you can suck or blow out the p traps. either way works.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
09-20-2021, 09:38 AM
2009 34' Panamerica
2005 28' Classic
Still
, in the thick of it
I was able to get a few gallons no problems. If shortage is coming, I'd get it now while it's still there. Picked mine up last weekend for the "P" traps, just put her to bed for the winter yesterday....good for well below zero.
09-20-2021, 09:41 AM
2014 27' FB International
Dallas
Anti-freeze
There was an entire pallet of RV anti-freeze at the Walmart in Durango, CO 12 days ago. I bought 4 gallons.
No shortage yet....
Brad & Rhonda
Lucy - 2014 27FB International Sterling
This is the sort of bloody nonsense up with which I will not put. - Sir Winston Churchhill
