Originally Posted by bsrobinson
What is the best way to retain natural heat inside the coach? I live in North Florida and need to learn how to keep the heat inside my coach through window coverings. For example, the skylight has a window covering. Should I keep it closed or open it to retain heat.
Well to "retain" heat, yes like others said close and insulate.
To let heat in you would open it.
If your staying in the trailer on a sunny day it "might" be worth it (depending on inside and outside temps) to open it from 10am-3pm. Otherwise best to close/insulate for overall heat loss verses gain.
