RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-23-2020, 12:10 PM   #1
some town , PA
Pull Batteries w/Solar?
My previous Airstream did not have any solar installed so I would pull the batteries as part of my winterization process. This past summer, we bought a new 2020 Airstream with factory 180w solar and AGM batteries.
Do I need to pull these batteries or would the solar keep them topped off protected from winter damage? The Airstream will be stored a few hours from my house so it's possible snow could cover the solar for a few days before I was able to go clear the Airstream after a big storm.
Thanks!
philly_air is offline   Reply With Quote
Old 11-23-2020, 03:06 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
No one has responded so I will. Solar will keep you topped off just fine. A few days should not be a problem, if snow covered. Probably your only parasitic drain is the propane detector and you should be OK. You could consider putting a switch in the power feed to the propane detector.
Larry
lsbrodsky is offline   Reply With Quote
Old 11-23-2020, 04:05 PM   #3
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
I’m with Larry on this; leave them in and let the solar top them off.
You can periodically check the battery voltage on the panel in the trailer or use an external VOM. This summer I installed a Victron battery monitor and plan to monitor the batteries via the Bluetooth app.
Last year I pulled them, put ‘em on the workbench and connected to my PulseTech maintenance charger to de-sulfate the batteries. I figured out how to connect the charger while leaving them in the battery box if they need a boost.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 11-23-2020, 06:59 PM   #4
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
That is different if the AS is in Alaska. snow will always cover solar... in PA? Not always in PA, right?
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Old 11-23-2020, 07:28 PM   #5
2018 25' International
Slidell , Louisiana
To add to Larry's sound advice, If you put the trailer in "Store" mode and the Solar controller is connected to the battery bus as it should be, you'll have about 0.1 amps parasitic draw if you don't have any shorts and no dirty connection causing cross draws. You can get rid of 0.03 of that by removing the inverter fuse. Okay so let's assume it has been overcast a few days and the batteries are also a bit sufacated so they are down to 75%. Let's say draw is twice expected. It snows and you can't get out there for 5 days. Even then you have 40 amp hours of good capacity and that will get you 200 hours or 8 1/3 day.
So, I'd say Larry is spot on.
Brian
BayouBiker is online now   Reply With Quote
Old 11-24-2020, 06:52 PM   #6
some town , PA
Thanks for the replies everyone! As I'm sitting here in Boyd's Key West campground I really don't want to think about winterizing upon our return to PA next week but I know it's got to be done. I really appreciate the help!
Old 11-24-2020, 08:03 PM   #7
2020 20' Bambi
Clayton , North Carolina
Please note that at least on the 2020 Bambi when you turn off the battery connect switch the propane detector no longer runs because AS are no longer wiring the propane detector straight to the battery, but rather via the battery connect switch. I went through all this couple months back with Atwood and AS. At first the AS CS said it was still connected with battery switch turned off but when I pressed them and said that Atwood said if the green light is not working then it is not connected. My green light goes off when I turn the battery connect switch to off. Then AS CS guy went to their engineers and the engineer confirmed that they no longer wire directly to battery. And the CS guy then conceded he was not up to date.
smsasf is offline   Reply With Quote
Old 11-24-2020, 08:10 PM   #8
2019 30' International
Pennsylvania , Pennsylvania
I'd pull them out of there and take them home, put them in the garage, check them occasionally and charge when needed.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 11-24-2020, 11:32 PM   #9
2015 22' FB Sport
Golden , Colorado
I recently sold my 2015 Sport 22 with 150 of solar and two Interstate lead acid batteries. The trailer was stored in Evergreen, Colorado, so plenty of snow. I left the batteries in the trailer, and the solar kept them in good shape with no problems.
WP53 is offline   Reply With Quote
BATTERIES. 2 NEW Interstate Batteries kapt59 Airstream Classifieds 1 08-20-2018 09:13 AM
Where to move batteries inside 23d. Upgrading to AGM batteries. Eyeballs Electrical - Systems, Generators, Batteries & Solar 36 03-08-2018 08:08 PM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 08:18 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 10:05 PM
