Old 03-23-2025, 05:45 PM   #1
2022 22' Caravel
Newton , New Jersey
Newbie Winterize and Wires Question
Picture below is taken by looking down under the closet.
1) trying to figure out what these two blue wires are for in the picture? They aren't connected to each other or to anything just terminate in red caps.
2) Winterizing videos show a clear tube connected to the water pump to siphon RV antifreeze with. This picture doesn't show it well, but there are just white pex tubes connected to the pump on each side, no clear tube connected anywhere at all. Is this a normal FB22 setup? Where would I connect the siphon tube to ? Thanks.
Topographica is offline   Reply With Quote
Old 03-24-2025, 04:09 AM   #2
2019 30' International
Pennsylvania , Pennsylvania
Not sure what the red wires are for.
The clear tube should be with your unit, unless you bought used and the previous owner didn't include it.
That clear tube has a fitting on it, you remove the fitting on water line that goes to the inlet side of the pump and screw the clear tube on at that point then put the clear tube in a gallon of pink stuff and turn the pump on.
One word of caution, when removing that inlet side fitting of the pump, there's a gasket in the fitting, don't lose it
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 03-25-2025, 06:15 PM   #3
2022 22' Caravel
Newton , New Jersey
Thanks majorairhead but alas no clear tube whatsoever, even 18"+ forward from the closet. Looks like AS forgot to install this one. Attached is another picture of the water pump. Small screen "filter" in-line but no "T" with a valve and a clear tube I will be going back to the dealer where I bought this used for another reason and see if they can put one in for me. Previous owner always stored in a heated garage so they never winterized thru the tube with RV antifreeze.
Old 03-28-2025, 08:02 AM   #4
2022 22' Caravel
Newton , New Jersey
Winterizing hose found!
The winterizing hose for the 2022 Caravel 22FB is under the sink. Pop out the large white panel under the cabinet below the sink - pull it straight out. The hose will be found on the right side attached to the "T" valve.
Can I bundle and route 110vac wires with 12vdc wires ? Aktundra Electrical - Systems, Generators, Batteries & Solar 13 05-14-2022 08:26 PM
Winterized, De-Winterize, Then Winterize Again Hoagie 2016 - Current Classic (all lengths) 20 12-12-2018 01:01 PM
Winterize - Question VaTravelers 2016 - Current International 9 01-27-2018 06:34 PM
7 Wires in, but 4 wires to lights..??? KZGoodchild Lights - Interior & Exterior 1 05-03-2017 04:10 PM
Help a newbie out....trying to winterize Bethy Ann 1970 - 1973 Sovereign 7 12-15-2009 11:00 AM
