Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 01-18-2007, 02:30 PM   #1
campadk's Avatar
2007 19' Bambi
Ottawa , Ontario
My Airstream Won't Fit in the Garage!
I know our Bambi won't fit in our itty bitty single car garage.. but I have discovered the solution...
We're going to BUY A NEW HOUSE!
So my question is what is the height, overall width and overall length including tongue of a 19ft Bambi? (can't measure ours.. its in storage).
I'm thinking of a house with a double wide garage with extra height... or ability to maybe increase the entrance to accommodate.
My our Bambi is sooo spoiled!
campadk is offline   Reply With Quote
Old 01-18-2007, 02:39 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Dave,
I am not sure about the new ones but the 70's vintage will clear a 10'-0" door with inches to spare. Overall length on a 19' Bambi should be pretty close to 19' I would get a 12' high by 40' long garage...then you can upgrade to a Classic
Aaron
WBCCI #XXXX AIR #2495
Old 01-18-2007, 02:39 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I would say 10' tall. I think Airstreams are about 9.5' tall, so 10' would be the min I'd have.
If you plan on ever upgrading to a wide body (25' or larger newer Airstream) I would say you'd want about a min of 9.5' in width.
If you stay with the 8' wide Bambi or non widebody, then I'd say 9 feet. That will give you 6" of clearance on each side.
Depth of the garage would depend mostly on what you might have in the future.
Old 01-18-2007, 02:42 PM   #4
Cloud10
smccollister's Avatar
2010 25' FB Flying Cloud
Fox Island , Washington
Images: 12
Would 10' also include the A/C unit at the top? I have a 2004 Bambi 16ft CCD.
smccollister is offline   Reply With Quote
Old 01-18-2007, 02:48 PM   #5
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
New House
We actually have some houses near us that have RV garages in their houses. They have two standard garage doors and one RV door. Your AS is actually 19.5' from tongue to bumper, 96" wide and 9.5' tall. Of course you will need navigation room and walkaround.
Make sure that if you are north that it is heated and south, that it is A/C!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 01-18-2007, 02:48 PM   #6
Aluminut
2004 25' Safari
. , Illinois
[quote=smccollister]
quote]
Yes. Most of the newer Bambi line is between 9.4' and 9.5' per the Airstream website. The Classics are about 9' 7". So, 10' would cover it, but that would be the minimum height I'd suggest. If you could go 11', that would give you a wider margin for error if you replace an A/C unit that is taller or upgrade to a Classic someday and say you want to put on an accessory....if you plan on ever getting a sat dome, then you'd want much more than a 10' high opening regardless if you had any Airstream.
Old 01-18-2007, 02:58 PM   #7
campadk's Avatar
2007 19' Bambi
Ottawa , Ontario
Great! Thanks all. I'm now ready to go measure a bunch of garages attached to houses for sale
Old 01-18-2007, 02:59 PM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
It does on mine...I think the normal road height on mine is 9'-7"...if all else fails load it down to compress the suspension and/or let some air out of the tires
Aaron
Old 01-18-2007, 03:00 PM   #9
Aluminut
2004 25' Safari
. , Illinois
Good luck...not a lot of houses have this as an option in the suburban parts around here, at least attached. Even the one's that I've seen in the rural areas are most mostly detached...I'm thinking that's the case because it's hard to incorporate a 30' deep part of the house and a 10' door into a house design....
Old 01-18-2007, 03:14 PM   #10
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Smile My Bamby will not fit
Hi dave,
If you are going to buy a new house with a garage that will hold your trailer, buy one that has at least 12 foot doors and is at least 50 feet deep. This way you can park your tow vehicle and trailer in the same place. My rv garage has 16 foot door, is 50 feet deep and 16 feet wide. This gives me enough room to park our AS and the jeep, but not enought room for the tow vehicle and trailer. For this I would need about 55 feet lenght.
Regards Russell from Tucson Az.
RUSSELL is offline   Reply With Quote
Old 01-18-2007, 04:23 PM   #11
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
While you are looking, remember to get the pull through model. Doors at both ends.
Royce (K0RKK) 146.460 simplex
Web page https://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is online now   Reply With Quote
Old 01-18-2007, 05:05 PM   #12
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Dave -- Airstream lists the length as 19' 2". Garage door widths usually come in even multiples down here in the "South" -- so 8' or 10' wide. I have the widebody and there is a 10' wide door at our storage garage. Sweet! I've backed the 7'10" wide Argosy into a garage with a couple inches clearance on each side and can virtually guarantee you'd want at minimum a 9' wide door. I won't even begin to suggest that you'd ever move away from your 8' wide 75th Anniversary ultra-Bambi!
5 meter Langford Nahanni
Old 01-18-2007, 05:42 PM   #13
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Remember - the 10 foot in high door is probably only good if there is little or no slope to the driveway - that 4-5 inches of comfort goes away with the trailer going in at an angle, up slope is bad. Good advice is to let some air out - just remember to inflate once in and then LET THE AIR OUT to pull out.
Wish I had built my garage after I bought my AS instead of before. Oh well, I need another building.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 01-18-2007, 05:57 PM   #14
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
That's funny Dave, we came to the same conclusion. Now we're looking for a new house for us and later on for building a two bay RV shop/garage.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 01-18-2007, 06:40 PM   #15
campadk's Avatar
2007 19' Bambi
Ottawa , Ontario
Well I'm not worried about 'upgrading' our Bambi later. Lots of good points.. er... pointed out here.
Storage in the garage when we move is one goal... maybe we'll realize it... maybe not. At least a car port for it would be a backup plan. We're looking at a semi-rural location with .5 acres or a bit bigger, so we might get lucky.
We actually got our boat in the garage last winter with 1 inch extra in length to spare, and about 1 inch on both sides going in... man that was a challenge!
Not sure if those double single car garages can be modified to a single wide door which would be a great solution if the house is configured that way. Also some garages are very high, yet the doors are only the standard 8ft heights or so. Some might be able to be modified?
Old 01-18-2007, 06:52 PM   #16
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Dave,
On modifying a double car garage door to a single large door...it depends if the door is on a gable end it is a definite maybe. If it is on an eave side it can be done but typically will require more structural work. It is more complicated than that but something to take into consideration. Best bet would be to have a dedicated shelter/barn built for it. FWIW I have a 40x80 shelter....and the Airstreams still sit out in the weather We are looking at building another 40x60 building...
Aaron
Old 01-19-2007, 05:00 PM   #17
Thealt's Avatar
1967 22' Safari
I think I have every man's fantasy.
2 car standard wide 1.5 deep car garage for the cars. 50' pull through garage long enough to hold the TV and the TT with room to spare. Big 12' wide doors, or at least a 12 in back and a 10' in front to match the width of the car doors. Only the height will be different.
I would find the house that suits you as this is where you live. Then build the garage that you want. Finding the exact thing really limits your choices. Much easier to build. Watch out for the zoning laws and neighborhood associations.
Did I mention putting a shop in the space leftover in front of the cars? Ooo la la.
Alt
Thealt is offline   Reply With Quote
Old 01-19-2007, 05:22 PM   #18
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
How about a picture or two of this dream shop, so I can get some ideas? We're looking for a house with plenty of space for this type of set up. Not so sure about the pull through though.
FF
Old 01-19-2007, 06:10 PM   #19
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Originally Posted by RUSSELL
Hi dave,
Well, shoot - you might as well put in a built-in automatic heated car wash with blow dry, etc, etc...
Fyrzowt is offline   Reply With Quote
Old 01-19-2007, 06:51 PM   #20
Thealt's Avatar
1967 22' Safari
You know.. after reading that.. I have to correct myself.. I meant i have the fantasy, not the shop , but I've done plans for the shop in the past.
If I find the plans, will post.
Alt
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
Airstream vs. Avion? 68 Suburban Vintage Kin 29 11-21-2008 07:35 AM
future airstream motorhome betteleal Airstream Motorhome Forums 11 02-12-2005 01:39 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
