RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-30-2020, 01:04 PM   #61
Waukesha , Wisconsin
Originally Posted by mkveseth View Post
You have to add it to water for it to work.
Not the pink stuff in the jugs. Use it straight as it is sold.
Adding water is for when you are using concentrated antifreeze for an engine, not for the pink stuff.
richard5933 is offline   Reply With Quote
Old 12-30-2020, 05:01 PM   #62
Lake George , Colorado
The key here is that it doesn't expand as water does.
2MileHi is offline   Reply With Quote
Old 12-30-2020, 06:45 PM   #63
2018 25' International
Slidell , Louisiana
The solution does not expand, but the slush does. Fortunately it is mobile and harmlessly pushes out of rigid enclosures.
Brian
Old 12-30-2020, 07:08 PM   #64
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Originally Posted by Spartanguy View Post
Today confirmed my deep mistrust of RV antifreeze. I put two jugs out last night because I knew a neighbor was bringing me over a Christmas plate and just sat the unopened jugs out on a spot of my sidewalk to alert of the ice on the concrete walkway, today I go out and the jug is partially frozen.
I promise I tampered with the solution in no way and removed the seal just today. As frozen inside as a slushy from 7-Eleven. It got down to 12 degrees last night, not -50 btw. Bottle was full, poured some out on my ice spot (not sure if that’s kosher or not, but not the topic at hand either way)
Thoughts anyone?
Merry Christmas,...
SpartanGuy
Attachment 385464
Attachment 385465
Attachment 385466
Yes it will slush. Not freeze....always did that..no problem
Old 12-31-2020, 01:29 PM   #65
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I imagine some people just drain the system and not blow it out. Not everyone has a compressor or the lungs of an elephant. There will surely be water remaining in low spots or drops that migrate to low spots. Every RV would have a different amount of water remaining, so only general answers can be made.
I always assumed water would dilute and reduce the usefulness of the RV antifreeze. Other posts seem to confirm (though it is opposite with traditional auto antifreeze—I thought the formula had changed to prevent deaths, but maybe I am wrong) that water makes RV antifreeze less efficient, so would pumping the antifreeze through un-blown pipes mix it with enough remaining water to make it work badly in some way? I doubt there is much scientific information this, but I don't read antifreeze journals. Perhaps it does not matter much unless you live north of the Arctic Circle.
The question behind my thoughts is whether newbies should be told they must blow out the pipes to protect them whether they use RV antifreeze or not? The answers may be dependent where you live, of course.
Gene
Old 12-31-2020, 02:39 PM   #66
It doesn't take that much pink stuff to flush water out of the lines. I watch the color as it fills a clear glass, and then let it flow for a bit after I'm confident that what's flowing is the antifreeze. With lines as small as we're talking about, there is not much mixing going on inside them. The pink stuff just pushes the water ahead of it. I'm not a hydrologist, but it's never been a problem for me.
Old 12-31-2020, 02:48 PM   #67
Slidell , Louisiana
Ethylene glycol remains the most popular antifreeze for heating and cooling applications including engine coolants. It's toxicity is moderate, get very drunk with grain alcohol to slow metabolizing the glycol and manage the produced formaldehyde to low levels. Same strategy for rubbing alcohol which is a bit more toxic.
RV antifreeze is premixed to 50% concentration for protection down to -50 with faucets left open, -20 if faucets, valves and fittings are all closed tightly. If you don't remove the water, dilution will occur so protection is reduced near the faucets depending on how much extra antifreeze is pumped to flush the diluted solution. Pump it till it is as pink as the original and leave the faucets open to let the slush expand.
Edit: there you go, what Richard said.
Brian
Old 12-31-2020, 03:11 PM   #68
dznf0g's Avatar
Oswego , Illinois
Ethelyne glycol has not been used in new cars for many years. Dexcool and others are propylene glycol...but a different formulation than rv antifreeze.
The early formulations were problematic in some applications.
-Rich-
Old 12-31-2020, 04:15 PM   #69
dznf0g's Avatar
Oswego , Illinois
Correction, ethylene is still used. Glycol is not.
Propylene glycol was used in early dexcool.
-Rich-
Old 12-31-2020, 08:05 PM   #70
Slidell , Louisiana
Ethylene GLYCOL remains the predominate cooling system antifreezes in all applications and for automotive engine use as well https://images.oreillyauto.com/uploa...%20Chart-1.pdf
Brian
Old 12-31-2020, 08:16 PM   #71
dznf0g's Avatar
Oswego , Illinois
https://www-hemmings-com.cdn.ampproj...like-a-rainbow
It has gotten really complicated and confusing, as many aftermarketers brand as dexcool compatible with different formulations. It's about IATs and OATs.
The big problem is incompatible components in various engine systems.
I would advise only using manufacturer recommended and branded coolant....especially on hybrids or EVs with battery cooling systems.
-Rich-
Old 12-31-2020, 08:48 PM   #72
Box Elder (formerly of Center Moriches, NY) , South Dakota
"The pink stuff" is doing EXACTLY what it was intended and designed to do.
NY24 is offline   Reply With Quote
Old 01-01-2021, 08:15 AM   #73
Half a Rivet Short
Carlisle , Pennsylvania
Hi
As long as we're getting into the grubby details. Check out a bottle of Miralax. Read the ingredient list ... there's only one ingredient: Polyethylene Glycol ( PEG ). Yes it's exactly the same stuff as is in our favorite "pink stuff". In addition to a bit of an aftertaste there are other effects of not fully rinsing the lines ...... it impacts both people and dogs ... I have empirical data on this, months of it.
Old 01-01-2021, 08:33 AM   #74
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Moot...all my 'pink' stuff is used post human consumption.
It goes from where it is now directly into the waste tanks.
Doesn't get put where it's not needed.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
“Change is the new normal, if nothing changes, nothing is normal, everything changes, everything is normal.”
RLC
Tahawus
ROBERT CROSS is online now   Reply With Quote
Old 01-01-2021, 08:35 AM   #75
Slidell , Louisiana
Bob, the laxative Polyethylene Glycol is is actually a poly ether (multiple ethyl ethers chained together) and is not used as an antifreeze, but does make a nice food grade lubricant. Propylene Glycol is an alcohol and is used in the pink stuff as an antifreeze. Ethyl alcohol (grain spirits) is also used.
Brian
Old 01-01-2021, 08:44 AM   #76
Good to know....👍
But I prefer to drink my grain spirits...Happy New Year.🥳
ID:	385922   Click image for larger version
Molly Ivins
RLC
Tahawus
Old 01-01-2021, 09:07 AM   #77
1969 18' Caravel
Greenville , whereEverIroam
Images: 20
Why I love the air forums
It's sorta like Spock walks into the bar from Cheers and Cliff Claven strikes up a conversation with him, and then a few blokes from Monty Python chip in with irrelevant insights.
Occasionally enlightening, always entertaining.
skyguyscott is offline   Reply With Quote
Old 01-01-2021, 11:49 PM   #78
1991 36' Land Yacht
West Paducah , Kentucky
And...
Knock Knock!
Who's There?
Ether!
Ether Who?
Ether Bunny!
ronreeder is offline   Reply With Quote
Old 01-02-2021, 11:25 AM   #79
Clearlake , California
Hi
Polyethylene glycol (C2nH4n+2On+1) is not the same as Propylene glycol (C3H8O2) as used in RV Antifreeze.
napabill is offline   Reply With Quote
Old 01-02-2021, 11:57 AM   #80
1969 18' Caravel
Images: 20
Thank you, Bill for pointing out that rather important distinction. Not that anyone here would drink RV anti-freeze, but if someone found themselves in an emergency situation, it's good to know that one can not substitute one for the other.
Is the pink stuff really required? Spartanguy Winterizing, Storage, Carports & Covers 39 12-25-2020 04:12 PM
Winterize, Pink Stuff, RV Antifreeze, Drain and Flush masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 12 11-19-2013 07:40 PM
Frozen jug of pink stuff Jammer Winterizing, Storage, Carports & Covers 7 02-08-2011 12:56 PM
First confirmed human contraction of... bake315 Off Topic Forum 6 02-25-2004 10:30 PM
Bambi holding tanks..HEATED..CONFIRMED dtbw 1997 - 2004 Bambi 3 06-30-2003 07:47 AM
