Old 10-17-2021, 05:41 PM   #1
2017 28' Flying Cloud
Upstate NY , New York
Low point valve question
Hey Everyone,
This is our first camper with low point drains. Our dealer winterized our camper but I noticed the low point drains were still closed. Should these remain open over the winter. What are these drains actually for? Are these to be closed during the camping season?
Deano112 is offline   Reply With Quote
Old 10-17-2021, 05:49 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Did the dealer put antifreeze in your pipes? If so, the valves are closed to keep the antifreeze from running out.
The valves are there so you can drain the water out to winterize.
The valves are closed during normal use.
CRH is offline   Reply With Quote
Old 10-17-2021, 05:49 PM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
If your dealer winterized using RV antifreeze they remain closed. If only blown out with air, I would leave them open. They are to remain closed when using trailer, otherwise your water will drain out when using the onboard pump, and will flow water all the time when connected to city water. If you have a manual, I strongly suggest having a read on the water system.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 10-17-2021, 05:52 PM   #4
Yes the put antifreeze in the system. I will make sure they’re closed.
Old 10-17-2021, 05:53 PM   #5
Yes they added the antifreeze. Thanks
Old 10-18-2021, 03:20 PM   #6
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
If you blow with air leave the valve open. Valves can't freeze up in the open position. There is a school of thought that says a valve will not leak later on if left closed. The thinking is the valve sealing faces can not corrode when closed. I leave mine open until I de-winterize. I have had no Leaks.
guskmg
Old 10-18-2021, 03:39 PM   #7
"Cloudsplitter"
guskmg
YES
I leave them all open, the only 'valve' closed is the toilet.
Don't forget this.
ROBERT CROSS is online now   Reply With Quote
Old 10-18-2021, 05:14 PM   #8
Originally Posted by ROBERT CROSS View Post
YES
Don't forget this.
By leaving them open, won’t some of the antifreeze drain out. I don’t believe they blew the lines out.
Low point valve upgrade question Melucy2airs 2006 - 2010 International 12 11-16-2020 08:18 PM
Low point valve leak john4170 Fresh Water Systems 2 08-29-2014 01:17 PM
Winterizing snafu - low point drain valve on FW tank stripped and won't opem bonginator Fresh Water Systems 12 09-29-2013 02:22 PM
Failure of low point drain valve? desidou Fresh Water Systems 8 12-24-2006 08:29 AM
