RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-30-2020, 12:19 PM   #1
2017 25' International
Bend , Oregon
Low point drains missing handles?
I am trying to winterize on my own this year after a couple of years having it done 'professionally'. My low point drains do not have any handles on them unless I am totally confused? I cannot believe that both would have fallen off. The dealer has winterized it and never mentioned this.
Is there some other way to open and close these drains and if not, is this some replacement part I can install?
Name:	low point drains.jpg
dilly dally is offline   Reply With Quote
Old 11-30-2020, 12:26 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
You can carefully put an adjustable wrench on the square operator. I am sure you can find some handles on line somewhere. Maybe Mcmaster Carr.
Larry
lsbrodsky is offline   Reply With Quote
Old 11-30-2020, 01:16 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Did you look in the drawers etc for the handles? Maybe in the space where the winterizing valve is?
Old 11-30-2020, 01:27 PM   #4
Bend , Oregon
Yes, we have been through everything they gave us and all nooks over the last couple of years, including the water heater bypass and the pump nooks. I guess I will just contact the dealer and see if they can provide these.
Old 11-30-2020, 02:31 PM   #5
2002 19' Bambi
Lafayette , California
Those look like standard ball-valve shutoff valves which are available at hardware stores. Amazon has several variations (for example: https://www.amazon.com/Akozon-Valve-.../dp/B07JKW53R9). It might be simplest to buy two new valves and use the handles from them. Then again, a plumber's supply company might sell just the handles.
Tim
Tim A. is offline   Reply With Quote
Old 11-30-2020, 03:36 PM   #6
Bend , Oregon
Tim
Thanks Tim - if that is a ball valve, seems like I am missing the stem too? There is nothing in that hole. Seems like the stem and ball should be integral?.
Old 11-30-2020, 04:32 PM   #7
Texas , Texas
In case you don't have the manual, here is a copy:
https://www.airstream.com/wp-content...manual-177.pdf
Looking at page 8-12 it does appear that you are missing some pieces.
Can you see into the threaded end to see if there is a ball inside?
BrentB is offline   Reply With Quote
Old 11-30-2020, 04:37 PM   #8
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
I think that you may be confused!
To me they look correct. The handles are circled on this picture. Turn them 90 degrees.
And pardon my typo!
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 11-30-2020, 04:41 PM   #9
Texas , Texas
And pardon my typo!
I could be wrong, but I don't think those are handles. I think they are "stops" for the missing handles.
Old 11-30-2020, 04:47 PM   #10
Bend , Oregon
Yes - I have the manual and see that photo now. I will have to go to my storage site again and crawl around to to see if I can see the ball. I am assuming something is there as I just got back from a camping outing and if there was nothing there, wouldn’t there be water draining out as I use the cold and hot water?
I am just wondering if it has been like this for three years and I just didn’t notice because I wasn’t doing the winterizing.
Old 11-30-2020, 04:54 PM   #11
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Are those really the low point drain valves? My low point drain valves are accessed from inside the trailer. My trailer is a lot older than yours.
Old 11-30-2020, 04:55 PM   #12
Mollysdad's Avatar
I'd be tempted to take one off and take it to a plumber or supply house. Just be careful to keep a wrench on both halves so nothing else moves.
The ball must still be in there otherwise water would pour out.
I wonder if they were removed to avoid road damage since they're on the bottom of the pan, yes?
Most of those on Google are 3/4" thread although I didn't see any just like yours.
I don't think you'll have trouble replacing it since it is a residential water heater drain part.
Old 11-30-2020, 04:56 PM   #13
Texas , Texas
It appears that the "stem" or "valve pin" as labeled in this video can indeed separate from the ball. If that's the case, it would probably be best to purchase new valves and replace the whole thing.
Old 11-30-2020, 04:57 PM   #14
Mollysdad's Avatar
To me it's the tab to prevent the handle from turning past 90 deg.
I took the liberty of brightening the image.
Old 11-30-2020, 05:17 PM   #15
2019 30' International
Pennsylvania , Pennsylvania
Call the dealer and ask them how they did it.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 11-30-2020, 07:13 PM   #16
1988 25' Excella
1987 32' Excella
Looking at the enhanced photo there is no stem. Probably no ball. Whatever those valves do I bet they are open.
Old 11-30-2020, 07:29 PM   #17
Silvr_Bullet's Avatar
42° 2' 27" N / 74° 7' 6" W , US
The threads on the discharge ( thread ) end is very strange. It looks like the valves were removed and maybe, just maybe the previous owner used this setup to blow air into the system for winterizing. I’am probably way out there on this.
Silvr_Bullet is offline   Reply With Quote
Old 11-30-2020, 07:30 PM   #18
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Are you missing the "guts" of the valves?
Was your system holding water up until now and now needs draining ... prank photo ???
2015 25' Eddie Bauer Int. / 2020 Ford Expedition 3.5 eco B
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Old 11-30-2020, 07:36 PM   #19
Come to think of it, those don't look like low point drains to me. I had a '16 Flying Cloud 25', and now a '19 International 30', and the low point drains were/are a red and white pex pipe coming out the bottom, just sticking out there, with the handles to turn them on and off inside the trailers.
Old 11-30-2020, 07:54 PM   #20
Piggy Bank's Avatar
I agree seeing the brightened image that that looks like where the handle goes.
Piggy Bank
30' International CCD low point drains? LivLoveLaugh 2011 - 2015 International 5 04-19-2013 08:12 PM
Low point drains in 2012 Mike-Gloria 2011 - 2015 Classic (all lengths) 3 03-18-2013 10:04 AM
2010 27FB Low Point Drains PJohnson Winterizing, Storage, Carports & Covers 2 10-31-2010 01:17 PM
front low point drains, 19' int'l ericwarren Winterizing, Storage, Carports & Covers 3 12-18-2008 03:58 PM
Low point drains runningbarre Winterizing, Storage, Carports & Covers 5 09-25-2008 07:07 AM
