Old 11-06-2020, 10:27 AM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Leave the suction tube on or remove
I had the quick connect to added a number of years ago to add anti freeze and it works great. However today as i was adding antifreeze a light when on inside my head and should I remove the tube and cap it or leave the suction tube attach.
Curious as to what others do
urnmor is offline   Reply With Quote
Old 11-06-2020, 12:42 PM   #2
aftermath's Avatar
Spokane , Washington
I had this set on my older trailer. Why would you want to remove the tube? There is a valve that switches back to your FW tank. Whether or not the tube stays attached has nothing to do with how the system functions. I might be missing something here but I would leave it in place for the next time.
aftermath is offline   Reply With Quote
Old 11-06-2020, 05:58 PM   #3
FishByFly's Avatar
2017 25' Flying Cloud
Fayetteville , Arkansas
I leave my attached and have a screw cap I put on the end. Keeps the tube from dribbling and anything getting into the tube.
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn
2023 F150 XLT
FishByFly is offline   Reply With Quote
Old 11-07-2020, 01:11 AM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I cap mine, but after using it for two years, I no longer need it. I blow out my lines, and everything else, and only put RV antifreeze in the traps. I'll leave it in for the next owner if there ever is one.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 11-07-2020, 06:28 AM   #5
1976 Argosy 26
Henderson , Kentucky
Images: 21
Never thought of this, so I leave mine attached. I do take out of bottle, hold up, with pump on to suck out any remaining fluid put finger hose end and open to pressurize slightly to suck again. Then shut off by-pass. I wipe off hose with paper towel. My thought is that don’t lose, if need again it is ready, and if by-pass closed no harm-no foul. You could cap hose end or rap with paper towel but I don’t. Now I will read other responses to see if I am wrong! Be Safe.
Be Safe. Mitch
Ky76Argosy is offline   Reply With Quote
Old 11-07-2020, 07:44 AM   #6
urnmor's Avatar
Berlin , Maryland
Not sure why I did not cap in the past other than I did not think of it,however, I will cap now. Thanks for the tips
Old 11-07-2020, 10:52 AM   #7
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I remove the tube and place the cap onto the valve finger tight, enough to compress the rubber seal.
Doing this keeps critters from hiding/nesting in the valve opening, which keeps them and their byproducts out of the fresh water system.
Alan
Interior vinyl and wood layer, to leave or not to leave? amaelish General Interior Topics 0 05-29-2017 12:18 AM
Suction cup dent puller gaiaenviro Classic Motorhomes 19 07-13-2015 07:52 PM
Can this dent be removed with suction? groovzilla 1974 - 1979 Sovereign 11 11-28-2013 11:41 PM
Replacing suction hose on 76' 31 Rear Bath DaAairstream Fresh Water Systems 6 05-03-2012 07:20 PM
Windshield Suction Cup Law rickandsandi Off Topic Forum 35 03-01-2007 09:25 PM
