07-06-2020, 02:57 PM
2016 27' International
North Augusta
, South Carolina
How to prep trailer for 9 months of storage?
I live full time in my 27FB, but I’m storing it in SC for 9 months while I’m deployed beginning in August. I’m going to winterize, wash/wax before putting it in storage. I won’t have anyone checking on the trailer while I’m gone. I found an indoor storage unit that will fit the trailer that also has power. I have several questions below for anyone who has experience or opinions. Thanks in advance for your help!!
What is the best thing and second best thing to do for the tires in this situation? (I’m a bit pressed for time, so any large project seems a bit overwhelming at this point. I’m looking for multiple solutions if the ‘best thing to do’ is involved)
Is there anything other than dehumidifying I should be thinking about for the interior?
Is there anything special I need to be thinking about for the exterior?
07-06-2020, 05:07 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Pump up the tires and Jack it up on stands...
Charge the batts fully and disconnect, with nobody checking I would not trust the converter powered up for 9mos.
07-06-2020, 05:49 PM
North Augusta
, South Carolina
[emoji631]
Bob,
Thanks for the reply! Do I use 1 jack on either side of the trailer or do I use more? Is it safe to be in the trailer while it’s on the jacks?
07-06-2020, 06:09 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
I put 'Cloudsplitter' up on jack stands every Winter.
One 4t stand between the wheels on the axle mount plate..
We are preparing for a trip to JC, it's still on the stands with the stabilizers down, in and out frequently, no concerns
Perfect stable & safe.
07-07-2020, 09:50 AM
2019 25' Flying Cloud
La Conner
Does anyone know whether modern tires are damaged by sitting in one position bearing weight for 6 months or longer?
Evidence for that claim?
07-07-2020, 09:55 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by cazual6
?????...... Jack stands don't go flat.😂
The torsion axles also need exercise, better to unload them to help prevent the rubber taking a 'set'.
TIRES LONG TERM ON THE GROUND.
07-07-2020, 11:14 AM
2016 19' Flying Cloud
Scarborough
, New York
There is damage created by leaving tires as you suggest. Do as the world auto industry does in inflate tires to between 55-60 psi. All cars in lot storage are treated to this formula. You can improve the formula by allowing the tires to sit on wood boards...not plywood thickness please....a bit like a 2x4. Car
manufactures cannot do the wood routine ! Why not put your trailer in jack stands and bring the tires inside like I do in the off season?
07-07-2020, 11:25 AM
2018 23' Flying Cloud
Hamilton
, Ontario
Air Circulation
When we leave our trailer over the winter, (November to May) we open all drawers, cupboards, stove, fridge, doors, underneath compartments etc. Propped with wedges or soft cloths if necessary to keep them open. We also prop up all cushions and don’t leave any leaning on the walls. This allows the air to circulate. We also leave a few mouse traps set but you may not have that problem!
07-07-2020, 04:40 PM
North Augusta
, South Carolina
Wow, thanks to everyone so far for the replies!
I upgraded my converter to a “smart” converter (Boondocker 1260 HWL) several months ago. Would you still suggest disconnecting the batteries?
I was thinking about leaving it plugged into 15 amp power and running a dehumidifier and ultrasonic pest repeller (in addition to moth balls & Irish spring soap to repel unwanted visitors)
07-08-2020, 06:18 AM
1999 28' Excella
Lake Mary
Storage
And do not forget to buy a bag of moth balls and spread liberally thru out the TT. Keeps out mice and bugs
07-08-2020, 07:11 AM
2017 16' Sport
N/A
, N/A
You didn’t mention if someone will check the trailer regularly I use a electronic rodent deterrent that I have found works well especially with the aluminum interior to bounce the sound around open all drawers etc including any hatches that lead to enclosed exterior compartments of the trailer. The dehumidifier will need attention also make positive that any discharge hoses are secure that they won’t somehow fall back into trailer and drain water. Being strapped for time I think these are of importance. I have very positive experience with the electronic devices, I use them in my garage where a squirrel took up residence, he moved on immediately.
07-08-2020, 07:38 AM
2018 28' International
Fayetteville
, Georgia
Disconnect the batteries. You do not want to risk one running dry while in storage and on a charger. Remove all food and paper goods. Drain flush and drain all tanks. Put a bit of water and a double dose of chemicals in the black tank after flushing. Keep jacks up. Consider buying new tires when you return.
And thank you for serving this great country. Be safe.
brick
2018 International Serenity
Cute wife...
07-08-2020, 04:08 PM
North Augusta
, South Carolina
I’m looking into the equipment I’d need to put the trailer on jack stands.
What do you prefer when/if you put your trailer on stands?
- A bottle jack stand combo ( https://www.powerbuilt.com/products/...nd-bottle-jack)
or
- A quick lift and jack stands ( https://www.homedepot.com/p/Sunex-3-...7JPK/303220873)
Definitely getting lots of moth balls and ultrasonic pest repeller to put outside of trailer (since I’m disconnecting batteries).
Tanks will be flushed and as clean as I can get them prior to storing. I wonder if the antifreeze will kill the enzymes that eat the bacteria from my tank cleaner ( https://www.amazon.com/dp/B075PZ8858..._FkKbFb6M836CN). I may just catch the antifreeze in a bucket when it comes out of faucets to prevent it from getting into the tanks and messing with the enzymes. Unless there are any ideas or suggestions on better tank storage smell solutions?
07-08-2020, 04:33 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
I would go with the HD option, it's in stock and more versatile.
As far as the tanks go...I'd flush both very well and leave them empty.
I blow the water lines with air, open the low point drains and faucets, and add AF only to the P-traps when I Winterize.
If it's going thru the cold weather, a full Winterization is in order.
07-09-2020, 04:09 AM
CapriRacer
I'm in the
, US
Yes, it is called flatspotting. Here's an SAE paper on the subject: https://www.sae.org/publications/tec.../2006-01-1629/
CapriRacer
Want to learn about tires? Please visit my website: Barry's Tire Tech New content every month!
07-09-2020, 04:34 AM
Sag Harbor
, New York
That paper is from 2006. With today's 2020 tire compounds, is flatspotting as much of an issue?
Quote from your cited paper:
"Tires flatspot when they remain loaded without rolling for a period of time. When the tires are rolled again, the initial flatspot decays and vanishes or stabilizes to a much smaller magnitude (called residual flatspot). Flatspot is a low harmonic phenomenon and primarily contributes to the first three or four harmonics of tire run out. The tire non uniformity caused by a flatspot may induce noticeable vibrations in some vehicles during operation in the decay process."
With the storage here being for only 9 months, is the "residual flatspotting" going to be a serious issue?
Also . . . per next post, if the tires are outdated, maybe get new tires after storage?
Thanks for you expertise on so many threads,
07-09-2020, 04:37 AM
Sag Harbor
, New York
. . . I would raise the stabilizers just in case you lose tire pressure.
Good advice, because the stabilizer jacks are not designed to carry the weight of the trailer, if one [or more] of the tires goes flat IMO.
07-09-2020, 04:42 AM
Sag Harbor
, New York
Do you know the DOT date-of-manufacture of your tires?
https://www.tirerack.com/tires/tiret...&affiliate=HK5
It may make sense to get new tires when you are back from your deployment?
Stay safe,
07-09-2020, 06:07 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
MOOT..if he's going with Jack stands.
BTW sitting on wet concrete in our area is not good either...covered on drainage tiles during the Season.
