08-29-2021, 12:14 PM
2017 23' Flying Cloud
Rocklin
How best to store an Airstream
When storing your airstream, should you leave it plugged into 110V and leave battery disconnect switch in "Use" mode? Or, unplug it from 110V and leave battery disconnect switch in "store" mode?
08-29-2021, 12:29 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard...👍
I store with the batt's fully charged, isolated completely, off shore power, with tires removed, on jack-stands and fully Winterized.
Others do other things, depending on other subjective options
POI I wouldn't store unattended on shore power 24/7
08-29-2021, 12:35 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The use/store switch does *not* fully disconnect the battery. A proper battery disconnect switch is needed if all you have is a use/store switch. The parasitic loads will flatten a battery in two to four weeks if only the use/store switch is employed.
As noted above, if the battery is healthy and fully charged, it can sit for many months without any issues *if* fully disconnected. There is no need to put a supplemental charger on a healthy battery. There are some potential issues if you do so that becomes very much a "maybe yes / maybe no" kind of thing.
Unless you simply never go off grid, healthy batteries are what you want on your trailer. If the batteries are dead / near dead, they will not store well and you also may not make it through the first night "out and about" ....
08-29-2021, 02:16 PM
1986 31' Sovereign
Miami
It depends. I live in a semi-tropical environment. When It is parked in the yard, it is plugged in, use/store switch in “off” and one of my fantastic fans is running in low with the other open but off (I have Ultra breeze covers so rain isn’t an issue. I find the steady low airflow prevents mold and musty odors. Every now and then, I turn the use/store switch to “use” for a few hours.
If I didn’t have power, I would pull one of the leads off the battery bank to completely isolate the batteries and leave both vents open.
If it freezes where you are, you might consider either pulling a battery lead (assuming the batteries are fully charged) or, perhaps, removing the batteries and storing them at home.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
08-29-2021, 02:54 PM
2007 22' International CCD
Corona
Proper disconnect switch installed. Cover is a double duplex outlet cover for wet areas with a bulge added with the cautious use of a heat gun and a 2x2 chunk of wood. Yes, I drilled 8 holes in the aluminum…to install switch and cover.
The switch is a two position battery switch good for 250 amps continuous load from BlueSea Systems and is connected with a 80 amp MRBF fuse bolted directly onto the positive post of the battery bank. (Two GC-2 golf cart batteries in series)
It kills everything except the tongue jack, breakaway switch, and WD jack system. They have their own fuse.
08-29-2021, 07:33 PM
2017 25' International
West Lake Hills
Is there a fuse that can be pulled to shut down everything from the battery?
08-29-2021, 07:39 PM
1986 31' Sovereign
Miami
Don’t believe so. The battery feeds the fuse bus…
Young, lovely bride
Dismissive cat
08-29-2021, 07:40 PM
West Lake Hills
Has anyone placed the shut-off at the fuse bus?
08-29-2021, 07:54 PM
Corona
On my Airstream the positive buss is under the front bed. Was easier to mount a switch outside. Crawling under the bed to flip a switch is not an option in an emergency electrical disconnect situation.
08-29-2021, 07:56 PM
West Lake Hills
Thanks.
So many mods; so little time.
08-29-2021, 09:06 PM
2021 30' Globetrotter
Oviedo
You probably need to define the word "store". I have a covered lot with power. I keep it plugged in and have been using it every couple of weeks. If I were to be putting it down for a month or two, I'd charge the batteries and disconnect them completely. I check the water level on the batteries every week or so. I don't have a true disconnect switch, so I'd pull the wires off the batteries.
It's not cheap to get covered storage. I like the idea of my aluminum beer can not baking in the Florida sun most of it's life.
08-30-2021, 06:12 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
I kept the use/store switch and mounted the disconnect next to it on the access door to the converter/charger, KISS.
08-30-2021, 07:23 AM
2014 25' Flying Cloud
Temple
We keep ours by our home and plugged in year around, we use it almost daily where it sits during winter months (mid Dec- Jan) and keep it ready to roll for a trip somewhere almost every month the rest of the year. Storage is not a consideration - we have it to use it.
2014 Flying Cloud 25FB
2018 Ram 2500; Cummins
Blue Ox WDH
08-30-2021, 08:58 AM
Corona
Ours is parked on our driveway, with the 150 watt solar panel exposed to full sun. I check battery water level once a month and have a battery watering system that makes filling them up easy. The solar keeps batteries fully charged so my fantastic fans run to ventilate the interior.
Heading out is quick and easy. Ready to go anywhere, anytime. Getting it lined up on the driveway when we return is the ‘interesting in the Spockian’ sense part because of too many cars on a relatively narrow street.
We unload parked on the street…
08-30-2021, 09:39 AM
2018 27' Flying Cloud
Atlanta
, Georgia
I keep trailer stored indoors in commercial RV storage facility. It is kept plugged in but battery disconnected.
Reasons:
1. Security against theft and vandalism.
2. No need to winterize or un-winterize.
3. Reduces damage from UV light particularly for tires.
4. I can pickup and go at a moment’s notice.
5. I think this will increase resale value.
Cost is $240/mo for 27’ Flying Cloud.
08-30-2021, 10:18 AM
2021 25' International
Plymouth
, Michigan
We store our 25FBQ in our shop whenever not in use for more than a few days.
Disconnect the batteries (store mode) from 12vdc buss via the battery disconnect switch at entry door.
Attach a Victron Blue Smart IP65 Charger, 10amp rated, direct to batteries for maintenance/monitoring. Charger integrates nicely via bluetooth Victron App. I could plug into building power via 30amp plug but I don't feel it's necessary to have everything constantly powered.
2021 International 25FBQ
2022 F-350 7.3 SRW CC LB
2018 F-350 6.7 SRW CC SB
08-30-2021, 11:31 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard 👍
I use that same charger on the boat, but unlike the Victron 712 it won't provide SOC unless it's plugged in.
Disclaimer...I do not leave ANY charger active 24/27.
Nice space BTW...what goes on the lift... Cobra?
08-30-2021, 11:45 AM
2016 30' International
Quartz Hill
I take my batteries out. Put them on the workbench at home and hook them to Battery Tender. It is a trickle charger that shuts down when batteries are fully charged. I check the water level monthly.
08-30-2021, 02:32 PM
2018 22' Sport
Ludlow Falls
, Ohio
I store my 2018 Sport 22 in my pole barn winterized with the battery disconnected and a charger on the battery to keep it up. A question I have is what is the best way for mouse control? I've used rodent repellent I've gotten from Amazon and so far so good. Looking
for other ideas.
08-30-2021, 02:43 PM
2018 16' Sport
Charlotte
, Vermont
Winter looks pretty cool right now, haha. Bramble, 12/20/20, winterized with air and antifreeze, unplugged battery, battery disconnect lever in store or off. As usual here, you get extra advice for free
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
