You can never get ALL of the water out. There will always be a little left in the tank but I would open the drain valve as a precaution. The little bit of water left in the tank will freeze but do no damage but the drain to the valve is small and may freeze and crack so open it and leave it open to drip out. It may be over kill but I remove the pump from my trailer and store it at home but removing the inlet and outlet and run the pump a few seconds is all you need to do to evacuate any water in it. This has served my well for many northeast winters.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
