Frame rust protection
During winter months where I live I’m concerned about frame rust because I’ve seen many videos of frame damage in older Airstreams and not much has changed in design.
I have found in my years of dealing with this problem in other vehicles that the only fix that works is to coat the frame with oil! From heavy motor oil (used if you want) to a product called Fluid Film which doesn’t drip like motor oil because it’s made from sheep fur oil.
You can paint it on your steel parts with a brush, spray it on with a cheap sand blaster, or use the sprayer provided in some of the Fluid Film kits. Doesn’t matter how you put it on just get it on there if you expect road salt spray in your area.
I have seen brand new Airstream’s that have gone to RV shows in winter months in Northern climates with frame rust starting already in their first year of life! This oil method stops rust immediately just re-apply as it washes off in about a year or so and those areas will never rot out!
