Old 12-08-2024, 04:40 PM   #21
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
It got up to almost 50F yesterday, so I could open the 2nd drain. I got a clear stream of water and then antifreeze, so I shut it and I'm assuming everything ill be ok if nothing was damaged.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Old 12-09-2024, 08:50 AM   #22
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
That's all you need to do. Sounds like it's fine.
Old 12-09-2024, 10:44 AM   #23
JeffKim's Avatar
2021 16' Bambi
Hi
Yes, it's finally good to move on with my life. Thanks!
2017 Audi Q7 3.0T
WBCCI 6343
Old 12-09-2024, 04:46 PM   #24
"Cloudsplitter"
Is antifreeze left in the lines popular these days?
We did it the first year and tasted it for months.
We pour it only into the traps.
SFSG here in snowy WNYS.
I’m an AS owner, and I'm really good at fixing things that aren't broken.
Old 12-10-2024, 08:13 AM   #25
Half a Rivet Short
2022 Interstate 24X
Hi
That's why we put it in and then blow it all out. You get the entire benefit of the antifreeze (no water left in the pipes) and the "taste impact" is greatly reduced.
Old 12-10-2024, 08:16 AM   #26
JeffKim's Avatar
2021 16' Bambi
We're having a brown winter so far in the Twin Cities, personally I'd like some of that snow.
I blow everything out and then pump the antifreeze through just to be on the safe side. In the spring I'll sanitize with a bleach dillution; the antifreeze gets pumped out and then I flush a few times after the bleach. With that we haven't noticed any antifreeze taste, but then we don't drink from the faucet that often.
2017 Audi Q7 3.0T
WBCCI 6343
Old 12-10-2024, 10:32 PM   #27
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
If the wrong type of pink antifreeze is used that will be a problem for sure. On our first RV we made that mistake once. We also put antifreeze in that RV's hot water heater - once. Took many fills/flushes to get it all out. Now we only use the stuff that is alcohol free and there doesn't seem to be any residual taste once the lines are flushed, and we don't put any antifreeze into the HWH.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 12-11-2024, 07:15 AM   #28
"Cloudsplitter"
Richard...
I've often wondered why I have a 'water heater' and everyone else a heater for hot water.
Sweet Streams
2016 25 ft flying cloud - forgot to open low point drains when winterizing? Bassmantweed Winterizing, Storage, Carports & Covers 14 05-12-2022 05:20 PM
I forgot to drain the tanks... BocaDad Sprinter and B-van Forum 33 07-07-2019 11:32 AM
forgot the low point drain rbs Winterizing, Storage, Carports & Covers 4 10-25-2012 09:49 AM
Failure of low point drain valve? desidou Fresh Water Systems 8 12-24-2006 08:29 AM
