02-20-2007, 07:03 PM
More than one rivet loose
Los Alamos
Florida is sold out!
I stopped today at Camping World near St Augustine. yeah I am heading north. I am going to need to winterize Buttercup for my trip into Washignton, DC/PA/OH.
I was shopping for a collapsible ladder and some RV anti-freeze. None to be found. I suspect anywhere north of Tampa is sold out!
Can I use Canola or Corn oil to winterize the traps, and tank? I am planning on blowing out the water lines.
Michelle TAC MT-0
Sarah, Snowball
02-20-2007, 07:10 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
I would just use some cheap wine Try your nearest Wallymart they have an RV section and typically keep the RV antifreeze in it...some autoparts stores may have it too.
Aaron
WBCCI #XXXX AIR #2495
02-20-2007, 07:11 PM
2003 22' International CCD
Kiln
, Mississippi
Are you go through Mississippi on the way home or another route? If so - you are welcome here. I have a gallon of RV antifreeze in the garage for you. BTW - Walmart here overstocked with RV antifreeze - lots of FEMA trailers but the people in them just don't care, many are being returned in deplorable shape. Drive safe.
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
02-20-2007, 07:15 PM
Naples
Antifreeze!!!
Hey Michelle,
I just spent 4 hours today rescuing a trailer that just arrived from Quebec. The poor folks had water coming out of every water fitting. The place where they store it was supposed to winterize it, but they only blew out the lines and did not add antifreeze.
The result was a busted water heater tank, a kitchen and lav faucet that were both leaking badly, and a dozen or so fittings that needed replacement. The only thing that held was the Pex tubing itself.
Try Wally World for some anti freeze if you can't find any at CW and be sure to open EVERY faucet to be doubly sure thatthe pink stuff is flowing thru.
lewster
02-20-2007, 07:17 PM
Los Alamos
I maybe coming through mississippi on I-40. I suspect this will be northern MS. I can check Walmart but I expect they will be out as well. Just looking for alternatives.
Michelle TAC MT-0
Sarah, Snowball
02-20-2007, 07:18 PM
Moderator Emeritus
1972 31' Sovereign
High Springs
Sanders had some for almost $10 a gallon. Used to get it in Ohio for $1.79.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
02-20-2007, 07:23 PM
Aluminut
2004 25' Safari
Vodka. Rot gut....nothin' fancy. Works in a pinch.
02-20-2007, 07:28 PM
Los Alamos
The factory blew out the lines back in Nov/Dec when they were fixing it. It is still doing ok. I have a short piece of hose so I can hook it up to the pump. I plan on draining the water heater and fresh water tank, activating the heater bypass and putting antifreeze down all the drains and holding tanks.
That should do it.
Michelle TAC MT-0
Sarah, Snowball
02-20-2007, 07:52 PM
Naples
That should do it.
Don't forget the lines for the toilet and shower......... and outdoor shower if you have one!
lewster
02-20-2007, 08:07 PM
2000 25' Excella
Kingston
Are you taking 40 all the way? I live right off of I-40 and there is a small RV store, right off the exit and they had a couple of cases of it yesterday. It is suppose to be in the 60's all week, so they may still have some, if you dont find it before you get here, let me know.
02-20-2007, 08:11 PM
New Borockton
That's what I was theenkin'
Really though, you should be able to find the stuff at any wally world along the way or in a pinch, SOB parts store along the highway.
888-828-1893
Bestconverter.com
02-20-2007, 08:59 PM
2002 34' Classic
Windsor
Michelle :
Two words to solve your problem...
"West Marine"
Your welcome.
Paul.
02-21-2007, 07:18 AM
Los Alamos
how many gallons? two? three?
Michelle TAC MT-0
Sarah, Snowball
02-21-2007, 07:24 AM
2019 22' Sport
High River
, Alberta
Originally Posted by lewster
Hey Michelle,
I would guess that they *may* have blown the lines out, but didn't drain the water heater at all. You can't get all of the water out, but a few inches in the bottom of the tank won't cause any problem as long as there is expansion room.
02-21-2007, 07:55 AM
Aluminut
2004 25' Safari
When disconnecting the pump from the tank and feeding the system straight from the bottle, I can typically do it in 2 or 3 bottles. Some do it in 1, but after blowing the lines out, I make sure the pink stuff gets everywhere...low side valves, water heater, traps, faucets, sink sprayer, head, etc...so 3 bottles....in my mind, it's cheap enough and having a bit too much is always better than not enough. Even if I spend an extra $3-4 for the added gallon or $6-$8 for 2 gallons more, in my mind, $8 is far less than the outcome of a possible problem.
02-21-2007, 09:19 AM
St. Cloud
Hadn't seen that this was about winterizing. Hope you have time yet -- but take the carbon filter out of the kitchen faucet before you run pink stuff through it. Otherwise you'll probably have to buy a new one.
Michelle, your karma account has a lot of upswing due. Wishing the best in travels to you! We're getting Gulf air this weekend with heavy wet snow before Sunday (mostly northern half of the state). I don't know the path predicted when it heads east.
02-21-2007, 09:21 AM
Pet Sitter Extraordinaire
1989 33' Land Yacht
Chattanooga
Antifreeze
Try auto parts stores too. I have been able to find it there sometimes too.
02-21-2007, 11:16 AM
Ready-to-Travel
2012 30' International
Walkerton
Good news is that you are catching us in a warming spell. I don't think you need to worry about it at all for the next several days - and there is always plenty of antifreeze up here. I think they ran out in the south because there is usually not much market for it.
Pat
02-21-2007, 06:19 PM
Los Alamos
I tried the local Wal-mart. Cleaned out.
The local auto parts place had three gallons. I bought them all.
Michelle TAC MT-0
Sarah, Snowball
02-21-2007, 07:11 PM
Naples
Albert,
I'm sure that they blew out the lines and neglected the water heater tank completely! Compressed air is a great way to get the lines ready for ANTIFREEZE. It is the only way to get the pink stuff into every nook and cranny in the water valves to keep them from exploding (which is what happened!)
A few gallons of antifreeze is really cheap insurance. The repair tab on this trailer is currently at $1250 and still rising!!!!!!!
lewster
