Old 10-29-2016, 09:15 AM   #1
Modesto , California
Covering Airstream Motorhome
I now you are not supposed to cover Airstreams. I can't find any "indoor storage units for RV's. I was wondering. If I bought an RV cover larger than our Airstream and built a frame out aluminum beams so the cover doesn't touch the Airstream would that work? We have a long driveway where it would fit. We wanted to build a covered carport to store it, but the city of Modesto requires that we build it 27 feet from the street gutter, so that's out! So I thought if we built a frame to go under the extra large RV cover it would keep the cover from touching the Airstream. Since it's removable the city wouldn't be able to make us move it. Any input will be appreciated.
Elskedeen1 is offline   Reply With Quote
Old 10-29-2016, 01:32 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Sounds like a good idea, post photos of completed project.
MICHAEL
Old 11-04-2016, 06:09 PM   #3
turk123's Avatar
2019 30' Classic
Sunnyvale , California
The only problem I see is if you get a wind storm. Anything that light will lift up and most certainly cause more damage than without the cover. That will be one big sail! I just can't think of another way to cover it. Maybe you can rent a barn in the area. Safer and protected.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 11-13-2016, 08:20 AM   #4
2016 30' Classic
Houston , Texas
Really understand your desire to protect your unit. I guess the concern regarding using a cover on an AS has to do with the risk of damaging the clear coat and underlying metal via cloth on metal friction. Your idea is a creative idea as long as you address Turk123's concerns about wind storms make sense. It would be most unfortunate if you eliminated friction risk and replaced it with failing aluminum frame risk. Maybe a good polishing combined with UV reflective window covers and RV tire covers is a route you should consider. If you go with no cover - frame or otherwise, I recommend that you treat your unit's seams and rivet heads with Corrosion-X (http://www.corrosionx.com/corrosionx.html) so as to help protect against aluminum filiform corrosion that may result from prolonged weather exposure. Good luck.
dhroberts is offline   Reply With Quote
New Airstream Outer Covering Morgan guy On The Road... 0 03-05-2014 01:54 PM
Covering airstream Mikeryan510 Off Topic Forum 9 11-25-2013 10:33 AM
Covering My Airstream and Caring for the finish Rollster Winterizing, Storage, Carports & Covers 18 12-24-2012 10:14 AM
Covering your Airstream wazzup Winterizing, Storage, Carports & Covers 55 09-22-2011 10:16 AM
