Old 02-28-2022, 05:59 AM   #1
GiaPK's Avatar
Classic heat issue
I winterized our 2021 Classic 30 by using the blow out method. I followed the valve settings in the owner’s manual. We went out this past weekend for a short outing, as we missed our AS. Got no heat from the Alde system. Checked the valves and found that the number 1 valve was still closed. I opened it and heard what sounded like a rush of water. Still no heat. I’ll be going over today to check the fuse. I’ve read about an air bubble getting caught in these systems and needing to be bled down. Any ideas on troubleshooting this? I was using power as opposed to propane for the energy source.
GiaPK is offline   Reply With Quote
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
