Old 02-18-2020, 07:05 AM   #1
2018 30' Classic
Houston , Texas
Alde while driving?
When traveling in sub freezing weather do you leave the Alde heat on while driving?
Jonesuh is offline   Reply With Quote
Old 02-18-2020, 09:59 AM   #2
2020 Classic 33
Box Elder , South Dakota
Yes, I set it for about 50 degrees.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 02-18-2020, 11:12 AM   #3
2019 30' Classic
2021 Atlas
Charlotte , North Carolina
We do too but set at 60. If the propane is on (refrig) might as well use it. We try not to clog the vents.
LilPeanut is offline   Reply With Quote
Old 02-18-2020, 02:00 PM   #4
2018 30' Classic
Houston , Texas
I’m leaving Washington DC Saturday and temps look to be in the 20s
Old 02-22-2020, 09:38 AM   #5
2020 33' Classic
Crosslake , Minnesota
Hi Gary, We're new to rving. So much to learn. Maybe you could answer a question. Leaving warm weather for cold. Do you know where the water pump is located, how to access and drain water out. We have a 2020 Classic 33 FB. Thc
David Fuches is offline   Reply With Quote
Old 02-23-2020, 07:52 AM   #6
2020 Classic 33
It is under the clothes closet in the bathroom. Remove the bottom left panel, just pull it out from the spring latches. It will be on the left side towards the back. It does get some heat since the Alde line runs along the outside wall.
If you need to drain it for storage you unscrew the outflow connector and remove the filter screen. Or use the rv antifreeze hose that is attached to run antifreeze through the system.
Gary
NØVPN
DC to AC inverter for fridge while driving the ponz Refrigerators 22 09-14-2021 12:33 PM
First Alde 3010 boiler to Alde 3020 boiler and Alde flow upgrade Sparr 2016 - Current Classic (all lengths) 64 08-15-2021 06:36 AM
ALDE HEATING SYSTEM FAILURE- Alde glycol discoloration and vent discharge JimskyD 2016 - Current Classic (all lengths) 50 05-25-2018 07:48 AM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 06:09 AM
Heat while driving? Krazykraut Airstream Motorhome Forums 4 12-08-2002 05:31 AM
